Page 1 of 3 123 LastLast
Results 1 to 25 of 71
    Active Member spyderryder53's Avatar
    Hanover CT
    Default uh oh stripped drain plug
    I was changing my oil and went to loosen the drain plug on the right side and it just spins
    I don`t even want think what that's going to cost to fix . so much for saving money
    Leon
    2022 marsala red RTL
    AND
    2014 RT S SE-6 COGNAC, 2010 RT 622 TRAILER TIMELESS BLACK
    BRP trailer hitch, Utopia back rest, Baja Ron sway bar , heim links. Elka stage 2 shocks front and rear.
    TricLed fender lights, saddlebag lights and mirror lights. LED headlights and fog lights, Wide vu mirrors.
    spyderpops LED bumpskid ,zippered cargo bag linings, Laser Alignment by Netzleys Tire, Stebal air horn
    stant gas cap,( Dimple oil plugs REMOVED ) JT dash mount.
    (Onboard) Lamonster Garage air compressor and intelliboost charger.
    Default Curious. ....
    What spins..?? the actual plug or the wrench..?? If the plug is spinning you would be having an oil leak. Crossthreading on installation I have seen, many stripped allen heads and torx but not any plugs. If it is just the allen/torx you can cold chisel on the edge and get it loose or it you can get a visegrip on it.
    Very Active Member jtoro1's Avatar
    Feb 2013
    port st lucie fl
    Quote Originally Posted by spyderryder53 View Post
    Leon
    You might have to take it to the dealer and have them install dimple magnetic drain plugs you will never strip them they are not Torx or Allens
    Hanover CT
    Quote Originally Posted by jtoro1 View Post
    I have the dimple plug in there the plug spins won`t come out
    Leon
    AND
    Oct 2014
    Fort Mill, SC
    Did you install the Dimple Plug or did the dealer? The fact that it is spinning on the way out, means someone stripped it on the way in and left it hoping no one would notice.
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    Member: American Legion
    Hanover CT
    the plug spins I have a dimple plug in there but when I went to loosen it up it didn`t seem to tight but it just spins now and won`t come out or retighten treads must be stripped on motor.
    Leon
    AND
    If it is the motor side wedge a blade between the plug and the case. Slowly loosen the plug. Hopefully it will catch and come out. Then you can helicoil it back to the original thread....
    Hanover CT
    Quote Originally Posted by Grandpot View Post
    I`m the guilty one here
    Leon
    AND
    Jul 2011
    Mitchell, Ontario, Canada
    I assume the right side drain plug is the one with the 2 o-rings and one crush washer. This is only a guess based on your description but I would say that the drain plug sheared off at the base of the threads. Now the rest of the drain plug is being held in by the o-rings.
    Nov 2013
    Oro Valley Arizona
    Righty Tighty Lefty loosey! Either you or your Mechanic should write this on your wall. We have all made
    this mistake. (except maybe Mike)
    ​Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Hanover CT
    not enough space to put anything in there tried that also put vise grips on so I could keep pressure on as I unscrewed it but nothing working
    Leon
    AND
    Jul 2011
    Do you know which drain plug it is?
    Hanover CT
    the small one
    AND
    Jul 2011
    the small one
    Well that's good news. You may not think so now.
    Chupaca is on the right track. Get it out of there and a helicoil to fix the threads.
    Hanover CT
    Quote Originally Posted by jaherbst View Post
    ​Jack
    I went righty but to tighty when I put it in I guess ( used a torque wench but hmmmmm )
    LEON
    AND
    Feb 2012
    Spring City,Utah
    Leon
    I have nothing new to offer you but I am sorry to hear of your problems. I hate it when a DIY project that should be simple turns into a mess.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Default Okay....
    Leon
    The dimple has a safty wire hole drilled in it. thread a strong wire through there with a long loop so you can put constant wieght while you turn the plug. The visegrips only give you a quarter or half turn. This way even if you crossthread it you will be able to get it out ...if not come on over I'll get it out.
    Hanover CT
    thanks I will give that a try
    if it works I`ll have a drink for the both of us
    Leon
    AND
    Nov 2013
    Oro Valley Arizona
    LEON
    I have given up on "Torque Wrench's". I have three of them and they are all different. I try to apply just plain old common sense. It has worked well for so many years. People usually tighten too much. Good and firm has always worked for me for my airplanes, boats, motorcycles and cars. Never owned a Locomotive so no opinion there.
    Jack
    2015 BMW R1200R LC
    Mar 2012
    NJ
    Jack
    Hell must be frozen over because I agree with you.[emoji38] I only use torque wrenches when I have multiple fasteners that need to be consistently the same torque, like a head for example or something very specific.
    The routine maintenance stuff is way more common sense.
    Like I tell my kid, you have to be smarter than the tool!😉
    Sent from my Nexus 6 using Tapatalk
    Aug 2013
    Colorado
    Did you mistakenly use 15 FOOT pounds with your torque wrench, instead of 15 INCH pounds?
    Hanover CT
    oh well that didn`t work
    Leon
    AND
    Default Have to agree...
    But the biggest problem is that torque wernches are like prybars. Because they are so long they allow you to over do it way to easy. I have a bunch but the built in one work best. Not saying this happened to you Leon...
    Default Yikes...!!
    Leon
    Any further suggestions require some home made tools and some good luck. You may give the local dealer a shot cause they may have the tools... let us know what does the trick....
    Mar 2012
    NJ
    Time to pull the motor and start taking things apart...
