XK Chrome Spyder Lighting Project
Finally completed my Spyder lighting project using the XK Chrome, 16.8 million colours, Bluetooth system. Has duel lighting zones (left and right), synchronizes to music, manual control of both zones with strobe and breathe modes, and a great safety feature where all lights turn red when you step on the brakes?
Reason: Link not working
Says this video is private - doesn't play
2020 RT Ride Frequent Stay Safe
Aftermarket Aux Light, GPS mounting/wiring, Lamonster Garage Mirror Lock, Lamonster Garage Belt Tensioner
Backrest Home Brew Mod
2008 RS from 2008 through 4/2015, 2015 F3-S from 4/2015 through 9/2020
working now - super cool
Nice Job! How many lights did you do and Where did you make the brake connection? I have not done the brake wire yet.
2017 F3 Limited
The problem is, the app has a store and the system can be expanded to lots more lights. I got a 12 light set and ordered 2 more along with a set of the 2 foot extention wires. I could add 4 more to get it how I want it.
2017 F3 Limited
brake light wiring
i have an LED license plate (cycle gear) and I wired it into the OEM connector, removed pin and weatherpac seal ran wire into connector and soldered it pin, put it back together then tied xkchrome to the license plate wiring
Improvise, Adapt, Overcome, Semper Fi
2020 RT
Limited heated seats
removable back rest & rack
XK Glow light
Paint with light painted panels
(Gone but not forgotten ) 2009 RS SE5
I was looking to see if there is a wire local to the fuse box near the frunk where I have the control module. It could save running a wire the full length of the Spyder.
2017 F3 Limited
I just updated the XK Glow App. It has a new feature. Its called Speed.It looks like a speedometer gauge. Im not sure how it works, Maybe gets brighter the faster you go?
On the Speed screen lower right corner,press and it goes to acceleration and the gauge reads G's
2017 F3 Limited
You are
correct I have tried it but on the speed setting seems to stay the same color i guess i need to slow down , i like the breath option, makes it look alive
2020 RT
XK Glow light
I went out to try the new features last night. The speed function, you can go to multiple colors menu the same as the theme menu that has Christmas joy, Passion heat..., only the colors change at different speeds. you can adjust the range of where it changes also by sliding your finger up and down the speedometer. Switch it to Acceleration and you can also go multiple colors the same way but it has more action. you can also adjust the G's to change faster or slower. I like it a little slower so it is not quite a distraction. I really like the new features and may leave it set there whenever I turn it on.
2017 F3 Limited
Tags for this Thread
