Ultimate TallBoy Seat Problems
I bought an ultimate seat at Spyderfest a couple weeks ago and up until today everything has been good. I left the backrest in the seat while I was at work, something I haven't done up until this point and now for the life of me I can't get the driver backrest to even engage to slide out of the housing. Has anyone had this problem in the past and if so how can I fix it. It wouldn't be a huge deal if I could put the rain cover over the seat but I can't. Would love some feedback and help.
You should try giving them a call; they're the ones best suited to give you advice about this problem:
1 877 672 0288
Good luck!
Thanks I called and left a message I think they are closed for the day
Update: a little wd40 in there and wiggled it a little and she came right loose that's a positive right? Lol
Seriously? You squirt a little lube in the hole and it slipped right in!?!? lol
On a serious note, did you look closely at the alignment of the bracket and make sure you're putting it in the right spot and at the correct angle?
I just installed my seat and it's awesome!!! Loving it so far with 0 miles, lol.
Lube worked amazing lol it was getting it out not in that was the problem lol. As for the angle and stuff yeah I did it like they showed me at install so idk what locked up. I'll bet you'll love the dear get out and put some miles on it
Buhaha....I read it too quickly. Hope you figure out how to put it in and take it out OK.
Glad to hear that you got things slipping and sliding!
Back Rest Removal
I was told when I got mine when you remove it to give it a hit downward first and then pull it out. There is a locking ball in there. That method has worked for me so far.
I was told to push down first then pull out.
Well it works but it's still a pain in the ass to get out
