Missing fingers right hand
Hi All
my name is David looking to purchase a new F3 but before I do was wondering if anyone knows if the trottle can be moved from the right side to the left was born with no fingers on the right hand any info would be greatly appreciated
thanks,David
Have you looked at Crampbuster? Simplistic but a heck of a lot cheaper then moving the throttle. Just an idea for you to try out.
2014 RT Limited SE-6 in Black Currant. Mods so far: Rivco Trunk Mounted Double Flag Holder Kit, Diamond R Drivers Tour Mug, Tric Led Drink Holder, BRP Hitch, Mini Trailer USA Nomad Trailer. RonBar and links, Spyclops I & II, Lighted Bump Skid, LED head and fog lights. Foam hand grips. A arm lights, both upper and lower
Let's see....
The question has been asked a few times and a search may help out. I don't remember seeing anyone with the change. Where there's a will there's a way no doubt. We also have a enables fourm I think you know that...may help checking with some folks there...
2012 RS sm5
I have a friend who was born without a full right arm. She has traversed the country on her 2008 Spyder GS which she had outfitted with a left footed gas pedal. She had the work done at a company that does handicap conversions on autos.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
I can't help with the technical issue, so I'll just say
I would try cramp paddle.
Ryde as if your life depends on it,
because it does !! Ryde Safe!
Vietnam 67-69
I have a friend that cannot use her fingers due an injury that left them turned up. She has been using a cramp buster but beware, the one she bought did not fit the grip very well, a bit too loose and our grips are tapered at each end. She is contantly trying to readjust due to it working to the left or right and not gripping correctly. Take a plastic zip tie and drill a single hole through the lower part of the paddle, you can then run the zip tie around and tighten it when it is in the correct position.
