Results 1 to 19 of 19
Thread: laser alignment
    Very Active Member irvin48's Avatar
    May 2016
    mt morris il
    Default laser alignment
    was told ,even when new you should have it done . if you had someone other than the
    dealer do it, what are the specs they need, or how would they get them. i know
    im getting ahead of myself, not having mine yet but just gathering all the info i can
    so i can hit my dealer with it. i hear toe in is all that can be set. thanks for any and all info.
    --irv
    2015 rts-white pearl- mods- '16 F3 fat 6 chrome wheels,
    and some little stuff. setback utopia backrest, baja ron
    sway bar, oem adj. air deflectors, marlin gps compass,
    lamonster fbb foot pegs[modified brackets], lamonts
    vibration damper, rock guard, and side case stiffener kit,
    . brp comfort seat. , fomozas and
    altimax, magic mirror mts, and wide mirrors.
    [joyce & irvin toms]
    Jul 2010
    Las Vegas, NV
    Default Yes
    They pretty much all need it. Yes, only toe can be adjusted, but 99% are off. We did 50 last week, and none were in spec. See spydercomfort.com for a list of laser alignment dealers. Insist on a Rolo/Outlaw laser alignment! It's the only one approved by BRP. Joe
    Joe Meyer
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by cptjam View Post
    What he said!
    Active Member vstrommer's Avatar
    Oct 2015
    miNNESota
    I had mine done last week at Spyderfest by Squared Away and Wow!!! what a difference it made..........Thanks Joe & Ann for the great job you did.
    2019 900 Rally , Black
    What he said!
    Throw another "" on the pile from me!
    Sep 2013
    Houston
    I have done quite a few and have not seen one yet that was in spec except my own F3 that Lamont did before I bought it. Some are worse than others but most are far enough off that a significant difference is noticed by the driver. Lower tire wear is usually enough to offset the cost of the alignment over the life of one set of tires.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Default Don't worry...
    If they do laser alignments on three wheelers they will know what the specs are. Just make sure they are able to reset the sensor with the buds system. Those that do slingshots don"t normally have the buds program.... I have had mine done twice due to wheel/tire changes....(Squared Away is the best)..
    ​2012 RS sm5
    May 2016
    mt morris il
    dealer doesnt have the rolo setup. manager said they will check w/their
    macine before putting wheels on. huh?! if it feels wrong there is a dealer
    about 70 miles from me. how much should i epect to get porked, i mean
    pay for this from a dealer?
    Invalid Emails
    Mar 2011
    Hudsonville, MI
    A dealer, kind of near me, charges $160.
    Registered Users Gray Ghost's Avatar
    Sep 2013
    Harper, Texas
    Quote Originally Posted by Joyce47 View Post
    I would not pay anyone to do the alignment if it wasn't ROLO. Can-Am aligns the spyders before they deliver them to a customer, but it is not as accurate as a ROLO alignment. Go to the Spydercomfort.com/dealers link mentioned in an earlier post and find one close. If there is not a dealer close check the independents as well, you may find one that is coming to your area.
    Clifford Fargason
    2013 Spyder RTL
    2007 Royal Star Venture
    Jul 2010
    Las Vegas, NV
    Default Kalamazoo
    We will be in Kalamazoo in June. If you can wait that long, we would be happy to square you away! Joe
    Joe Meyer
    Nov 2012
    North Las Vegas, NV
    --irv
    http://www.spydercomfort.com/dealersil.htm
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Active Member kbwitt's Avatar
    Jun 2015
    AZ
    Hi how long does it take to get it done. Start to finish.
    Thanks
    Jun 2010
    Las Vegas
    Quote Originally Posted by kbwitt View Post
    Thanks
    It takes us about 30 minutes if we don't have too many questions.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Active Member Dragonfly's Avatar
    Apr 2013
    Atkins, Arkansas
    I must have hit the jackpot as the 1% that did not need it. Picked up my RT this morning and no adjustment was needed.
    May 2016
    mt morris il
    got my rts this pm and dealer said they had ordered the new laser system and when it came in they would do mine
    for free. cant do any better than that.--irv
    Jun 2010
    Las Vegas
    they need a Guinea pig
    2010 RT- 622
    Jul 2010
    Las Vegas, NV
    Default Yikes!
    Tell you what, I'll check it for you. I will be in Kalamazoo in June. Ride over, I'll check it. It takes a few repetitions to get it right. You can see for yourself if it is right. It's math. You will be able to see for yourself if it is right. No question; it is in spec, or not. If it is, you will know. If not, I will square you away! Around the lake - an easy ride. Joe
    Joe Meyer
    May 2016
    mt morris il
    over 300 miles 1 way and around chicago ? i hate doing it in a car.
    ill let them do a few before mine.
