Passenger speakers
Just purchased a 2012 RT Audio and Convenience. I thought there were passenger speakers, but no sound. How can I find out?
2012 A & C
My X - GF had that model and it had rear speakers.......Check your preferences screen and see if they are turned up loud enough so you can hear then........Although the sound won't impress you, the BRP - RSI 4" speakers break up sooner than the fronts .......IMHO........that's why I changed to the JBL - 2 OHM models................and they will ROCK YOU.........................Mike
We got a new to us 2012 RT A&C last fall, you can barely hear the rear speakers, I've tried changing the fader and balance and it makes very little difference. Must just be one of those things, I couldn't hear it anyways unless I was stopped so it's not an issue for me.
Go to the setting that will let you put more sound to the rear. I run 2 plus to the rear.
Passenger speakers don't work.
Still no sound. How do I get inside the rear speaker housing?
The AC model did not come with rear speakers. That is an add on.
If you want to put them in yourself you will need the speakers AND the wiring. There is a kit from BRP.
http://store.spyder.brp.com/product/...Audio_Controls
I did a video when I upgraded my Speakers and show you how to get at them in the front and rear.
Originally Posted by BLUEKNIGHT911
been there done that ( a few times )........The entire side housing must come off, and to do that a lot of the rear has to be re-moved first.................WHY do you want to do this ....maybe I can help before you do it .......Mike
Just want to get sound out of the rear speakers. Suggestions?!
REAR SPEAKERS
Apparently Her A & C had the speakers as an ADD-ON......so as Bob said they aren't standard........Mike
Thanks for the video!
(I just ordered speakers for my RT, and now I have a better idea of what I'm up against!
The USPS has delivered me a HUGE project...
I might just chicken-put, and call the dealer!
Turn about is fare play
Rear speakers RT S 2015
Ok I must be missing something because I am unable to get any sound out of the rear speakers. Does anyone have a suggestion?
