Oils....one of the top three topics...Gas, Tires, oil and you will get more opinions than Pontiac sold GTO's... The oils of today (name brands) are all comperable and each have a following. I for one like the synthetic blends but fall in a minority. I have never had any oil issue with them and they have saved my butt in more than one occasion. But full synthetic is the way to go for some types of ryding....
Gene and Ilana De Laney Mt. Helix, California
2012 RS sm5
Since oil is too small a word for the search function on here you need to do a search for the brand of oil (amsoil, castrol, mobil) you might be using or just do a search with the word synthetic. I'm sure you will find enough reading to keep you up at night.
With this question you will receive opinions, unless you can find a Tribologist. My opinion is to go with full synthetic, but that's just my opinion, not necessarily based on facts.
2011 RTS (Sold to a very nice lady)
1998 Honda Valkyrie
2006 Mustang GT. Varooooom!
US Navy Veteran
SC Law Enforcement Boat Captain
CNC Machine Service Technician
President: Rolling Thunder SC1
Member: Disabled American Veterans, Rock Hill, SC
Member: American Legion
Experience is recognizing the same mistake every time you make it!
This has to be the true 'Never Ending Story'. It's hard to come up with an opinion that someone won't try to shoot holes in.
But in a nutshell. Let me attempt this. For the most part, fully synthetic oils are better in every respect when compared to standard or blended oils. After all, the reason they put a 10% full synthetic oil into standard oils (making them a blend) is for the sole purpose of improving the characteristics of the original lubricant.
I think the real question that has never really been full answered is. Does your engine NEED the superior properties of a fully synthetic lubricant? And there-in lies (I think) the seeds of debate.
Now please give me a moment while I don my proximity suit!
Use the XPS 4-STROKE SYNTH. BLEND OIL (SUMMER) (P/N 293 600 121) or a 5W40 semi-synthetic (minimum) or synthetic motorcycle oil meeting the requirements for API service SL, SJ, SH, SG or higher classification. Always check the API service label on the oil container.
AJ
Originally Posted by lilwill
I read in my manual it calls for a synthetic blend oil. Is anyone running full synthetic if so does the motor run better / cooler
2014 RT-S Akrapovic Exhaust & Cat Bypass
Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
Comfort Seat w Adjustable Backrest
Decals by Purple Harley / Magic Strobe
Kuryakyn Black Widow Pegs Rivco Highway Brackets
Rivco Trunk Mounted Double Flag Holder
FOBO / Spyder Cuff / XM Radio w MC Antenna
Full synthetic for me, Amsoil 10-40. I do not know what the benefit is to a blend other than a slightly lower price
mark
Hi Mark.......I have bought quite a bit of Valvo-line 10/40 & 20/50 full syn ...." 4 Stroke -motorcycle oil " ( silver containers ) for as little as $6.35 per qt. at Walmart..........and this stuff has the second LOWEST amount of Moly in it..( bad for wet clutches )...............only Amsoil has slightly less.........................Mike
I've ran both,
1st oil change BRP's blended
2nd oil change BRP's XPS Full Syn
3rd oil change BRP's blended again
4th oil change (last one) Amsoil 10/40 Full Syn
My opinion BRP's blended ran better that the XPS, quieter shifting and the Amsoil seems to run the best and that's what I'll be "sticking" with!
my belief is that your engine will last just as long with the blend oil as it will with full synthetic.But you will have better protection from the synthetic if you overheated your engine
I am running Valvoline Full Synthetic 10W-40 ( 4T Stroke) motorcycle oil, Superior Wet Clutch Protection. ( 5 quarts)
My spyder runs fine, with the Full Synthetic.
Deanna
Gremlin Bell
SpyderPops Missing Guard Belt
Ultimate F3 Floorboards
Sway Bar with Links
Rolo Laser Alignment
Half Cover
Show chrome Trunk Shock
I've ran both,
This is a common thing from everyone I hear that has run Amsoil is the shifting on the SE models is a lot smoother. I am an Amsoil fan and was just about to put it in my ST for the first time and then I traded it. So I will have it put in my F3 at my first service.
2016 Spyder F3 Limited Steel Black Metallic
Lamonster approved LED Headlights
Lamonsters LED Fog lights
BRP Driver & Passenger backrest
BRP Trailer Hitch
Shamrock Black & Polished
Signature light
Elka front shock's
Dual Power outlets
Garmin 590 GPS
I
Is this oil ok to use?..These classifications are confusing,especially when XPS don't put any on their bottle..I have a 2012 RTL..
Reason: add info
Finished my first oil change, the bike has 1700 miles on it. ( it was killing me trying to wait till 3k for first oil change) . It was rather simple and straightforward. I went with amsoil 10-40 full synthetic motorcycle oil and BRP filter. Only found a few metal shavings
WOW .....I have the same engine and changed the oil early also.........................but didn't have any shavings on the plug, some very small metal particles........but nothing that large ............................Mike
I don't want to be a kill-joy. But that amount and size of material would rate as 'seriously concerning' on my worry scale. Your magnet will only pick up ferrous materials, and not 100% of them. The Spyder engine has a great deal of non-ferrous parts that won't show up on a magnet at all. Did you inspect your filters for debris?
It is possible that these are simply leftovers from the machining/assembly process. But modern engines aren't supposed to be left with that much junk inside. I would consider doing another early oil change just to be sure there isn't any additional 'Stuff' accumulating on the magnet. I would also highly recommend inspecting the reservoir screen.
I don't believe I've ever seen Rotella diesel engine oil mentioned on Spyderlovers. I've heard from several others with a wide mix of bikes, quads, trucks, cars, etc. that used Rotella diesel engine oil in all of their motorized vehicles and were very pleased. I've never used it and don't know anything about it; what opinions or experiences are there by you fellow Spyder riders?
Rob
2015 RT-Ltd SE6 and F3S SE6, both with a number of commercial add-ons plus my own tweaks.
WOW---I'd be anticipating a short engine life with those size of shavings---U sure ur paper clip box didn't fall into the oil filler opening? Houston--I see a problem developing--I would take those photo's to the dealer & document the metal filings occurred prior to your own initiated oil change---if the mnfg can find a way out of warranty--they might blame the problem on your own oil change..
Finished my first oil change, the bike has 1700 miles on it. ( it was killing me trying to wait till 3k for first oil change) . It was rather simple and straightforward. I went with amsoil 10-40 full synthetic motorcycle oil and BRP filter. Only found a few metal shavings ...
+I'm with the others. I don't consider those "shavings"...
Let us know what the dealer says. If you sit on this one they may say you could have prevented further damage if you'd said something sooner. At least you'll have this on the books so if something does go wrong you have this on record.
Believe me. None of us are happy to give you this kind of opinion. Hopefully, this will all work out well. That's what we all want to happen.
Hang in there and keep us informed if you think it will help.
I spoke with the dealership, the maintenance dept. told me that it was noted on my account. But from what they have seen with other bikes it seems to be normal
