Results 1 to 21 of 21
    Springfield, MO
    Default Lamonster Approved LED Headlights
    I bought 50 sets that turned out to be junk so I went with the best there is on the market. No moving parts to fail. Check it out.
    http://www.lamonstergarage.com/h4-le...ght-for-f3-st/
    Bossier LoUiSiAna
    Guessing we do away with the BRP rubber boot, that is on there now, when we upgrade?
    Active Member CharlieIndia's Avatar
    May 2011
    Washington Pa.
    What is the degree of difficulty to install? Can-Am doesn't always make it easy to get at the bulbs.
    Mar 2015
    US
    Thanks....
    I just ordered mine and will finally make the headlight match the LED's on the from end of my F3s
    Will there be an install video for these guys?
    Mark Hood
    Bullies are sad pathetic People
    Springfield, MO
    The rubber boot is reused. The heatsink will unscrew for insulation.
    Quote Originally Posted by CharlieIndia View Post
    It's a pain to get to the bulb but it's no harder than replacing the stock bulb.
    Quote Originally Posted by Nyparrothead View Post
    Thanks....
    Mark Hood
    I have no plans for a video right now because it would take too long to shoot. I try and keep everything under 10 minutes and that's not going to happen on this. Best to get a service manual to help you.
    Aug 2013
    Northern California
    Default What
    Nothing for the RT?
    Very Active Member armyspydervet's Avatar
    Nov 2015
    Occoquan, VA
    Quote Originally Posted by Lamonster View Post
    Will you be doing installs at Spyderfest, or is it too time intensive?
    Chris
    2016 F3-T SE6
    Springfield, MO
    Quote Originally Posted by Pirate looks at -- View Post
    Nothing for the RT?
    The RT is a 9005 and they are in route.
    Quote Originally Posted by armyspydervet View Post
    No, we are limited on our time so that one will suck up too much time. Sorry
    Aug 2013
    Northern California
    Default Thanks
    I will look forward to their availability.
    Jul 2010
    Las Vegas, NV
    Default RT 2014
    Lamont, get a set in, I'll buy them for Ann, we can video the install. I replaced her headlight bulb in a mud parking lot in northern Canada. Should be easy in your shop or the fairgrounds! Much less mud!!
    Joe
    Joe Meyer
    Springfield, MO
    Quote Originally Posted by cptjam View Post
    Joe
    Thanks. I hope they make it in time. The F3 is harder than the RT to install, that's why we won't be doing them there.
    Active Member fencepost's Avatar
    Apr 2010
    Thorn Hill, TN
    Installation is pretty simple, if you access the headlight bulbs per BRP instructions you will need the following; T15, T25 and T27 Torx drivers, 7mm wrench, small wire cutters and 6 ea. 7" zip ties. I've been told, after the he fact, that you can just remove the screws holding the side rails on and slide to one side replace bulb and then do the other side.
    Mar 2015
    US
    Quote Originally Posted by fencepost View Post
    Could you explain... There is a different way other than the BRP manual?
    mark
    Apr 2010
    Thorn Hill, TN
    By removing the screws holding the side rails you will be able to lift the panel up and to the side to access the headlight bulb. I would suggest that you tape off the of the fairing so as not to scratch it when you move the panel to the side. I did not do it this way, I followed the BRP instructions and would do it again if the need to access the bulbs was needed. Having total access is more important to me than trying to hold a panel to one side. Even with the tape I would still be concerned with scratches on the fairing.
    Apr 2013
    Hartsville, S.C.
    What are you calling the "side rails"?
    Apr 2010
    Thorn Hill, TN
    The correct name is Console Header they hold the instrument cluster.
    Springfield, MO
    We use microfiber towels. No issues.
    Jul 2010
    Las Vegas, NV
    Default Fingers crossed!
    I hope they come in for Ann. Meanwhile, my buddy Sue on an F3 wants a set. Of course, I need to install them! However I can help, just let me know. Videos, instructions, whatever. Stock lights suck! More light is always better! Joe
    Joe Meyer
    Very Active Member 900Dave's Avatar
    Jun 2013
    Fleetwood, PA
    I pick up my F3 Wednesday, my lights should be here by then. I plan on installing both the headlights and fog lights on Thursday or Friday. I will take some pics as I go.
    2016 Spyder F3 Limited Steel Black Metallic
    Lamonster approved LED Headlights
    Lamonsters LED Fog lights
    BRP Driver & Passenger backrest
    BRP Trailer Hitch
    Shamrock Black & Polished
    Signature light
    Elka front shock's
    Rolo Laser Alignment
    Dual Power outlets
    Garmin 590 GPS
    Jun 2010
    Las Vegas
    Ann really doesn't want them.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Aug 2008
    Maryland
    Quote Originally Posted by 900Dave View Post
    Thank u in advance for posting pictures as u go including panels please - also any tips/lessons learned along the way appreciated. Fog lights easy but I am concerned about getting to the headlight bulbs. How many Spyderlovers does it take to change a headlight bulb in 2015 F3s? Beats me. I only know that the time is to long for a video installation guide - HEY! we need a Bob Finless for F3's.
    I have read the owners manual steps to changing headlight bulbs but perhaps there are some missing details or easier ways of doing it.
    Cheers and the best of luck.
    2020 RT Ride Frequent Stay Safe
    Aftermarket Aux Light, GPS mounting/wiring, Lamonster Garage Mirror Lock, Lamonster Garage Belt Tensioner
    Backrest Home Brew Mod
    2008 RS from 2008 through 4/2015, 2015 F3-S from 4/2015 through 9/2020
