Results 1 to 8 of 8
    May 2015
    Abbeville Al
    Default STS Mirror problem
    Hi all,
    The mirror on my wife's 2013 STS has been hit and moves in and out. I was reading and there is a mention of a tab and you have to slide the mirror forward to remove. I know I am missing something. Can someone give me directions on what has to be removed and how to get the mirror off to see what is broken. Is the tab on the mirror or panel?
    Feb 2014
    Roswell NM
    From memory:
    Remove the clear wind deflector
    Remove the body colored panel below the mirror.
    To remove mirror, give a sharp rap straight up. The farther away from the body the better. This will dislodge the bottom two pins that hold the mirror in place. They are held by springs. The sharp rap/hit releases the pins from the springs.
    The top pin is held by a little mickey mouse piece of plastic. If anything broke, it is most likely this little piece of plastic. Part should be available from the usual suppliers.
    The plastic piece is held in be three (or four) bolts. You will see them all once you remove the mirror.
    There is also an electrical connection. It is obvious.
    Active Member nhoj's Avatar
    Apr 2012
    Aurora Ontario, Canada
    Marilyn 2023 RTL Red
    John 2023 RTL Black
    previous:
    2015 RTS SE6 Red
    2015 F3S SE6 Silver
    2011 RT SM5 Silver
    2013 STS SM5 Silver
    "common sense will prevail....but we see no sign of that"
    Bossier LoUiSiAna
    Quote Originally Posted by jcasey View Post
    Hi all,
    Just curious how only the mirror was hit? Sounds more like a vandal than accident Just a redneck opinion
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    May 2015
    Abbeville Al
    Thanks!! My search did not find this. Going out to ty will let you all know the verdict
    Jul 2011
    Mitchell, Ontario, Canada
    It won't be broke. Just popped out.
    2018 F3 LIMITED
    May 2015
    Abbeville Al
    Thanks for all replies. It was just popped out. All fixed and I got some well needed ataboys.
    Oct 2015
    Lynden, WA
    Thumbs up ST Mirror
    Thanks for this very timely post.
    I just bought LEDs that I plan to put in the bucket behind the ST mirrors.
    Was agonizing over removing the mirrors but no more.
    Great timing.
    Cheers, David C.
