Results 1 to 5 of 5
    Mar 2015
    forrest above Reno, Nv
    Smile LED signal lights/ backup lights
    Installed LED backup and signal lights on my 2014 RTS. Extreamly bright!!!! Remove 21 Torx drive bolts and the rest is easy. Do the hyper flash dance ( Hold the flasher button down, don't just press it)
    Seriously, the LED lights are very,very bright.
    Kaos
    2014 RTS , Circuit Yellow
    Default Well done...
    Must be bright and very visable...key word is visable... although it won't do it justice would give a hint of the effectiveness of the led bulbs ...
    ​2012 RS sm5
    May 2015
    Oregon, USA
    Thanks for the info, but...
    -Fratz
    Mar 2015
    Thumbs up Really Bright
    A quick glance at the sun might give you you some idea. Light intensity fall off at the Square of the distence so when i first fired these puppies up I was at about arms length. Really bright. After trying to remove the hyperflash, I stood about twice as far back---Still painfully bright.
    I'm not sure a picture would do justice unless I open up the back end of the again and put in the incandescent bulb for comparison. Just trust me ----- the LED bulbs are ------Really Bright.
    Kaos
    Active Member Upstater's Avatar
    May 2015
    Upstate NY
    Quote Originally Posted by kaos View Post
    Kaos
    How about vendor info? Where/who did you purchase from?
    2012 Spyder RT SE5 Limited - Lava Bronze
    - Baja Ron Sway Bar - SmoothSpyder Belt Tensioner - Air Modification Kit - Motorcycle Dave's gel seat inserts
    - Rivco Floorboards - Show Chrome Trunk Rack - Bad Boy Wolo Air Horn
    - FZ-1 Fuzeblock - Hopnel Lid Nets - Monster Graphics
