SpyderLovers Sponsor
Another great deal from Ron. If I didn't already have one, I'd jump on this deal.
We all appreciate what you do for us. Thanks.
2008 GS.....PE # 2888
Gate Belt Tensioner
Bummer..!!
already have one but thats a great deal...
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
already have one but that's a great price
2015 RTS Special Series
Russell Day Long seat
F4 Customs windshield
Sena 20s
Looks like something I need in my toolbox!
Ron can you post that chart that gives the recommended tension for all our Spyders? I remember you posting it on another thread but this thread can be a better go to to find it.
Also where on the belt is the best place to get a reading? Can it be done on the bottom side? I would have to remove lots of tupperware to get to the top side.
2017 F3 Limited
The instructions say to put the gauge centered on the belt left and right and also centered between the 2 pulleys and that is what I have always done. If you do the bottom of the belt you'd need to do it from the underside (flat side). I would take several readings from the top of the belt and then several readings from the bottom. If the tension reading is the same or close then I don't see any reason you couldn't use the bottom of the belt. It will probably be more difficult using the tool upside down but not impossible.
I've gotten a lot of inquiries about setting the proper belt tension with the Krikit II. This tool is simple, very easy to use and quite accurate when done correctly. But you need numbers!
Doing some research and crunching/converting the values (Newtons to Pound Force) this is what I came up with. The original Newton specs. came off of the Internet. You should check your owner's manual to verify my numbers.
Tension values for the 2013-2015 Spyder Belt are higher than for the 2008-2012 Spyders. I did not calculate 'Wheel on the Ground' figures for the 2013-2015 models as they will exceed the 330 lb. measuring limit on the Krikit II gauge. 2013-2015 Spyder owners will need to raise the rear wheel off the ground to get an accurate belt tension measurement with the Krikit II gauge.
998cc All Models (2008 - 2012) |
Min |
Spec |
Max |
Newtons - Wheel Elevated |
300n |
450n |
600n |
Pound Force - Wheel Elevated - Krikit II |
67 lbs. |
101 lbs. |
135 lbs. |
Pound Force - Wheel on the Ground - Krikit II |
130 lbs. |
160 lbs. |
190 lbs. |
998cc All Models (2013-2015) |
Min |
Spec |
Max |
900n |
1050n |
1200n |
202 lbs. |
236 lbs. |
270 lbs. |
1330cc All Models (2014-2015) |
Min |
Spec |
Max |
900n |
1050n |
1200n |
202 lbs. |
236 lbs. |
270 lbs. |
Thanks Ron, I also found the thread that has more discussion that you posted.
http://www.spyderlovers.com/forums/s...hlight=newtons
2017 F3 Limited
Belt Tension Gauge
Ron, thanks for the link to the video and the table with tension numbers. I'm searching for suggestions for reducing belt vibration and came across this.
-Bill
2019 Black F3-T
