Results 1 to 17 of 17
    Active Member View from behind's Avatar
    Aug 2015
    Taylors SC
    Default Zumo tire pressure monitors
    Anyone using the Zumo tire pressure monitors and if so are you happy with them? Also, is it necessary to change the valve stems to steel?
    Active Member NM Wrench's Avatar
    Apr 2014
    Albuquerque, New Mexico
    I use the FOBO ones
    Sent from my VS990 using Tapatalk
    14 RT-S , Stock Large brake pedal White Pearl
    Active Member Mtrprts's Avatar
    Sep 2015
    Birmingham
    Also using Fobo. Very accurate. I would like to use the zumo just to have to look at only one screen but don't have the right gps for it. I would also like to hear from someone using them.
    2014 Spyder RT-L Pearl White
    Akrapovic Silencer, BajaRon Sway Bar/Links, BRP 23" Vented Windshield, BRP Adjustable Wind Deflector,
    BRP Heated Seat/Backrest, BRP Sirius, BRP Bluetooth Dongle, BRP Tri Axis Handlebars w/GPS,
    CD Brake Light Modulator, CD Short Antenna, Elka 1+r Shocks, ISCI Brake, JT Dash Mount, Lamonster Cat Bypass, SP Bumpskid, SP Kott Grills, SP Belt Guard, Smooth Spyder Belt Tensioner
    May 2015
    Oregon, USA
    I also use the FOBO ones, and they work great with the regular rubber valve stems.
    -Fratz
    Bossier LoUiSiAna
    Quote Originally Posted by View from behind View Post
    Honestly thought this was a typo... Research & found garmin does offer a tpms for the 390 or 590 units worth looking into. http://www.revzilla.com/motorcycle/g...essure-monitor
    the FOBO has also had good reviews & few more spyder related info. So Want to find out. Problem however is I have the 660 that it does not work with.
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    Also using FOBO
    AJ
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
    Jun 2014
    ny
    The only problem with using a valve cap design tpms would be i can't then use my spyder valve caps
    Very Active Member 2ndChildhood's Avatar
    Sep 2012
    Flushing , Michigan
    I'm using the Zumo tire pressure on my RT now for almost 13,000 miles with no problem. I did not replace the valve stem to steal. I thought they were a little expensive but I do like them. I'm using the Zumo 390.
    ToM
    Do what you like
    Like what you do
    Life is good
    Life is Great
    ToM
    Aug 2015
    Taylors SC
    Thanks to everyone for taking the time to respond. We are going to try the Garmin ones as we already have the GPS.
    Sep 2015
    Birmingham
    If I already had the correct gps, I would do the same thing. If you don't like, you can always go to the Fobo system. Good luck with them. Give us a report.
    Jul 2013
    Marietta, GA
    Default to: o.p. Garmin TPMS
    I have a set, for the 590 (390) never used, still in original boxes
    If interested p.m. me
    I'm going to spyderfest. are u ?
    Feb 2016
    California
    Thumbs down I would not buy again
    I just left my two wheel which had Zumo tire pressure to a Garmin Zumo 590 LM. They drove me crazy, never worked right, constant reading on my GPS popping up saying they could not be recognized. I was going to look into something different for the Spyder
    Aug 2015
    Jarrettsville, Maryland
    Quote Originally Posted by LSommers30066 View Post
    I'm interested, how much?
    Jul 2013
    Marietta, GA
    Default Garmin TPMS - Sold
    The garmin Tpms - sold
    Mar 2012
    Spokane, WA
    I like the idea of being able to use my android rather than gps to check tire pressure. Now I have a good quality gauge and use it.
    2015 RTSE, Red Pearl, Shorty Antenna, Chrome Rear Rack, Deer Whistles, BajaRon Anti-sway Bar
    Active Member SpyderSteveFL's Avatar
    Dec 2015
    South Florida
    Pros and Cons to both. I have the 590 but went with FOBO. I read the FOBO sensors were newer and more accurate? But I also rather be able to check with my phone at all times other than riding. It's nice to check from instead the house before you even go out, or when filling I have phone right there, no need to turn GPS on. Also the warning is nice, not sure if the Garmin has that. At the end of the day I think either is better than nothing but I really like the FOBOs.
    NEW/CURRENT (Wife's Bike, I ride Goldwing/Africa Twin)
    2023 RT Limited Petrol Blue Metallic
    Working on the upgrades... so far... Show Chrome Isolator Fuse Block, Tackform Adventure Wireless charger phone mount
    OLD/TRADED
    2015 RT Limited Intense Red Pearl
    Farkles: Ultimate Tallboy seat, FOBO, JT Dash Mount, Lamonster Spyder Cuff, Kradellock, TricLED lighting - fenders, A-Arms, saddlebags, run/brake, Custom Dynamics high brake light, brake modulator, Drink2Go passenger, MUTH turn signal mirrors, Bajaron sway bar, Kuryakyn ISO grips, SpyderTV front grilles & rear trunk organizer, homemade trunk light
    Pending: Elka shocks, Yokohama S Drive rear tire, EVO 595 front tires, Centramatic balancers, Neutrino black box
    Very Active Member robhowen's Avatar
    Apr 2015
    Tucson, AZ USA
    Default Ditto
    I use the Zumo TPM as well on the stock valve stems. No issues after 5K miles.
    Rob
    Quote Originally Posted by 2ndChildhood View Post
    ToM
    Do what you like
    Like what you do
    Life is good
