Fuse?
Good afternoon peoples, having a hopefully minor problem on my 2012 rts info : everything was working fine then I put in a new battery charged it took it for a run and now no Cruise Control the clutch engage switch seems like where I should be looking is there a fuse for that system and if so where it does start in gear with the clutch lever pulled in so any help would be greatly appreciated Thank You
