View Poll Results: Is Plug & Play important?
Voters
81. You may not vote on this poll
  • Plug and play with oem connectors is the only way I'll buy a part.
    38 46.91%
  • I'm good with tapping using a quality connection like a Positap
    14 17.28%
  • Does not influence my decision at all.
    16 19.75%
  • I'd prefer a choice of tap and plug and play knowing that the tap version is less expensive.
    13 16.05%
Page 1 of 2 12 LastLast
Results 1 to 25 of 28
    SpyderLovers Sponsor lewis/ec's Avatar
    Apr 2013
    TN, Knoxville
    Default How important is "Plug & Play"?
    When you look at products, how much do you base the purchase of the part being plug and play?
    lighting - electrical - tutorials @ Electrical Connection
    Danbury Connecticut
    Quote Originally Posted by lewis/ec View Post
    A lot ! Thanks to engineers (and I'm one of them) things are getting so complicated that you need a degree in electrical engineering to work your toaster.
    IBA #47122
    2020 RT Limited Asphalt Grey
    Aug 2012
    CO
    For non-critical applications, good ol positap is fine since I have a modicum of shadetree mechanical skills. But with a lot of Spyder's systems it messes with the CANBUS and other circuits, throwing codes etc - I'd rather have P&P.
    JLohPhotos
    2008 GS , Millennium Yellow
    Default PLUG & PLAY
    I'm a DIY'er and design and build all my Farkles from things I find on E-bay. It mostly involves re-purposing something that it wasn't designed for originally..................And I dis-agree with asp125 on the Can-Bus thing above.......IMHO it effects very little that you would be FARKELING ................Mike
    I am at the bottom of the heap when it comes to installing farkles. On an item as complicated (for me) as the , I defer the installation of 99% of the accessories to the dealer or helpful mechanic friends who know the . In this case it was the NtA people who visited last summer. I got lazer alignments and had KOTT grills installed.
    Aug 2007
    Springfield, MO
    I'm good either way but my customers prefer plug and play. It's not always that easy to do as you know.
    Active Member SpyderF3-s's Avatar
    Oct 2015
    Menifee, CA
    Default COST!
    I'm with BlueKnight911. I like to get stuff off Ebay and make it work for me. I like the challenge.
    God bless those who serve/served our country!
    Idaho
    Mostly I make my own OEM compatible connectors wherever I want to connect directly into the Spyder harness. For me, it's a more wallet friendly approach. I like to stay away from tapping into the bike wires as much as possible. Plus, a lot of plug n' play doesn't play the way I want it to play!
    2014 Copper RTS
    Very Active Member robmorg's Avatar
    Oct 2013
    Pottstown, PA
    .......IMHO [the Can Bus] effects very little that you would be FARKELING ................Mike
    I agree with Mike. But I still prefer "plug 'n play" simply because it's easier, and it generally does not cost a lot more. OTOH, if there is an electrical farkle I want, that it NOT plug 'n play, I wouldn't hesitate to buy it. Given options, I would put more emphasis on the quality and operating features, rather than the "plug 'n play" feature, but if all else is equal, I'll choose the plug 'n play. (There was no choice on the survey for this answer.)
    Rob
    2013 RT Limited
    My "Mods & Farkles" Link
    May ALL your roads be beautiful
    Greisemer's Mill Bridge, Oley, PA
    2013 RT Limited , Lava Bronze with Antler Brown Seat
    Mar 2015
    forrest above Reno, Nv
    Smile Solder and shrink tube?
    I know how to solder and properly use shrinktube. I don't like crimps at all. Ask any V-max owner---- A factory crimp is the first thing you fix ( by soldering). Plug and play is good------ but many,many electrical problems occure at some kind of connection or switch.
    Electrical problems cause::::
    Kaos
    2014 RTS , Circuit Yellow
    VIP Member Lady Lamonster's Avatar
    May 2011
    Nixa, MO
    I prefer my things as idiot proof as possible.
    Default Tough one...
    Depends how much you are comfortable doing. I can go either way but will admit the plug and play is cut and dry in many cases much like its name. Being much like BLUEKNIGHT911 I like making my own and find it quite easy to do....plug and play is a great help to those that don't...
    ​2012 RS sm5
    Active Member KJWEB's Avatar
    Jun 2015
    Midland, TX
    Quote Originally Posted by Lady Lamonster View Post
    No worries there Joan, you got the Lamonster!!!!
    www.sasspyders.com
    2016 F3T
    2015 Freedom Trailer
    Sypderpops BumpSkid Plate
    Lamonster ISP Key Cover
    Lamonster F3 Bar Clamp and Power Port
    Lamonster RIP floorboards and frame caps
    Lamonster Chevron Highway Pegs
    BajaRon Swaybar & Heim Links
    F4 Custom 21" tinted windshield
    BRP Cannonball Seat
    BRP F3 Idler Pully
    FOBO TPMS
    LidLox (dual)
    Garmin 660LM GPS
    Cat Delete Performance Pipe
    F3T Top Case
    PPA Black Widow Wheels
    Custom Frunk Wrap
    Default STRANGE AND AMAZING - FARKLE'S
    Quote Originally Posted by robmorg View Post
    Rob, to bad you aren't going to Spyderfest, you will miss the un-veiling of my AMAZING " AMBER GLOW " which is completely scratch built from raw materials ........But you will see it at SPYDERQUEST ...............Mike
    Default SHRINK TUBE
    Quote Originally Posted by kaos View Post
    Kaos
    Heat Shrink tubing seems to be very expensive for what you get, until now......BANGOODS.COM sells the stuff in one meter lengths for approx.$ 2.00 to $3.00 delivered .....this is the smaller sizes that you would use 4mm to 8mm read the specs carefully because some of it is double shrink but the good stuff is triple shrink with adhesive .....Happy shopping.........Mike
    Very Active Member JerryB's Avatar
    May 2014
    Beaverton, Oregon
    Hi lewis,
    Re: how much do you base the purchase of the part being plug and play?
    I'm a retired Mech Engr; luckily my son-in-law is an Elec Engr.
    I've been working on vehicles since I bought my first one in the summer of 1954.
    I've done my share of stripping wires, crimping/soldering, heat shrink tubing; you name it.
    If I were developing a product, I would make it 'Plug & Play' as much as possible.
    I can agree with BlueKnight911 & Chupaca; I can make it work from parts but at this point in life I prefer to keep the stress to a minimum.
    You need to know your market; and Spyder folks are older than the norm. I think that it is called KISS.
    Many, many years ago I was offering some thoughts to a guy who was developing a product. He said that he wanted it like a telephone. In those days, when the telephone guy showed up, everything that he had to install or take out was simply plug & play. The telephone company saved a lot of money when they went to that system.
    Jerry Baumchen
    PS) Your question is exactly the reason why I had you send me the install instructions for your LED taillight product.
    'I'll never forget what's her name.'
    'Things are more like they are now than they ever have been before.' Dwight Eisenhower
    2008 GS SE-5
    Very Active Member Ron2andia's Avatar
    Jun 2012
    Phila
    I like to dabble and install but always prefer P and P!
    Live, Love, and Ride! God Bless!
    Nov 2013
    Oro Valley Arizona
    Quote Originally Posted by SpyderF3-s View Post
    LOL
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    May 2015
    Oregon, USA
    I sure don't mind a little crafting, but I want to know that when I'm done it's going to work, and what is going to be involved.
    -Fratz
    Registered Users SpyderTwyn's Avatar
    Mar 2016
    Florida
    Default plug and play, please
    I'll be late to the farkle party. I have zero mechanical ability. That's why the Limited was a great choice for me....
    Active Member Myersd802003's Avatar
    Feb 2016
    Alamogordo, NM
    As long as I have a video or instructions to install, like Lamonster's products, I'm good either way.
    2012 RSS (Wife's)
    2015 F3S (Mine)
    Active Member siny10309's Avatar
    Dec 2015
    Tropical Island ____________of Staten
    I think if you can make something plug and play you would have everyone who is interested in the product buying it. If it is not you are probably eliminating about 60% of your customer base.
    2015 F3 SE6
    Since I'm at the bottom-end of the "Skill-Pile"; I prefer Plug & Play...
    But since I'm also just stupid enough to think that I can do it; I'll cut into wires, and make all sorts of adventurous things happen!
    Mar 2015
    Smile Thanks,Mike
    Thanks, Mike,
    I got a good buy at a local store that was having a big sale. I like the fact that I now have a good selection of different sizes of shrink tube. I still have some from decades ago that a friend gave me ( it's too small for even medium gauges of wire though). I just like the current carring capasity of a soldered joint.
    Kaos
    Default HEAT SHRINK TUBING
    Thanks, Mike,
    Kaos
    .......I agree on the soldering thing, and I hope people don't think you can just twist wire together and use HEAT SHRINK on it and that it will be fine .......Mike
