Results 1 to 11 of 11
Thread: Oil Change kit
    Very Active Member rcturner's Avatar
    Jun 2012
    Fairmont, Minnesota
    Default Oil Change kit
    Last week I brought my 2014 RT-S home. I also bought an oil change kit just to have on hand. I noticed that the manual says that oil and filter change requires about 5.6 qts of oil. My kit has 7 qts. Anybody know why?
    Very Active Member bmwlarry's Avatar
    Mar 2012
    Beaverton, Oregon
    I have bought 1330 kits from dealer and mine did not have 7 qts?! Are you sure?
    2015 an Am Spyder RT Limited
    2013 Yamaha WR250R - Sold
    2011 Can Am Spyder RT-S SE5 Limited - Sold
    2011 Aspen Sentry Trailer
    2003 BMW K1200LT - Sold
    2007 Unigo Trailer - Sold
    2001 BMW K1200LT - Sold
    2001 Honda 750 NightHawk - sold
    2015 RT Ltd , Canamspyderaccessories Brake pedal ext. Red
    The SE6 kit has 7 quarts. The SM6 kit has 6 quarts. No one knows why and BRP isn't saying...
    Default WELLLLLLLLLLLLLLLLLLLLLLLLLLLLLL - MAYBE
    To justify the outrageous price they charge for what they are selling ........I buy my own OIL ( and it's FULL SYN ...not blended like BRP ) and filter from Bajaron ( cool guy ) and it cost me $45.00 ......Mike
    Jun 2012
    Fairmont, Minnesota
    Is the SM6 kit the same as the SE6 except for the extra qt of oil?
    Quote Originally Posted by rcturner View Post
    Yes, same kit but for the 1 qt difference.
    The trans filter for the SE6 is sold separately and, as everyone knows, needs service every 28k.
    Invalid Emails
    May 2011
    Gulf Coast of Texas
    you may want to check, there was a bulletin that went out correcting the amount of oil required.
    I have a 2015 Rtsm6 and run 4.9 qts. it's full. top of the mark. The extra oil cause crank pressure which in turn had effects on power.. Double check guys.. Maybe Lamont can chime in on this.
    Jun 2012
    Fairmont, Minnesota
    I have seen the transmission filter available on your listing. Is there any BRP magic involved in changing this filter ?
    I have not done the trans filter change myself. But it appears to be a pretty straight forward job. The filter itself is a 1 piece configuration. Looks to be plug and play. I've sold several and have not heard anything back from the customers. So I assume it was pretty much a no-brainer.
    When stuff works I don't always get feedback. When it doesn't work, 100% feedback is the norm. If you know what I mean!
    Member Smutt's Avatar
    Nov 2015
    Nl Canada
    Here in Canada the SM6 and SE6 uses the same oil change kit part# 219800356, it has 6 US quarts. I bought one last week, on the box it says oil change kit 1330 engine, no mention of SM6 or SE6. Jim
    2015 RT Limited
    Show Chrome Drivers Backrest
    Show Chrome Passenger Armrest
    Show Chrome trunk Rack
    Ron's Shock Adjusters
    Ron's Sway Bar
    BRP Trailer Hitch
    CB Communications System
    Spyderpop's Bump-Skid
    Spyderpop's Belt Guard
    JT's Rear Fender
    Quote Originally Posted by Smutt View Post
    Maybe BRP figured it out then. Very interesting.
