Results 1 to 10 of 10
    Sep 2015
    Missouri
    Default AirHawk Seat Cusion size for F3; R or Medium Cruiser?
    Getting ready for Spyderfest and not sure which size fits better. Historically I believe it was the R for other models, but the dimensions for the F3 driver's seat made me wonder if the Cruiser fit better.
    Anyone with F3 AirHawk experience?
    Thanks!
    Very Active Member Mike,P's Avatar
    Sep 2011
    Wales , Michigan
    Quote Originally Posted by GatorMan View Post
    Thanks!
    I use an Airhawk R
    Active Member Hitman5363's Avatar
    Jul 2015
    Azle, Texas
    Quote Originally Posted by Mike,P View Post
    I use an Airhawk R
    Mike,
    Are you using the large or small on your F3? My cannonball seat is 14.5 wide but the large is 14 inches long which would hang over the tank area......if I go with the small it is only 11 x 11 so won't touch the tank area but a little narrow.....
    Suggestions??
    Very Active Member vondalyn's Avatar
    Jun 2012
    Longmont, CO
    I'm fairly sure that my husband's airhawk is a cruiser model. He used it on his Yamaha Vstar 1100 classic. It works just fine on the spyder F3 without rubbing on the bodywork in front of the seat.
    We now have His and Hers Spyders!
    Current Spyder: White 2015 F3-S SE6
    His Spyder: White 2015 F3 SE6
    Previous Spyder: 2012 RT Limited SE5 -- 30,300 miles
    Previous rides: Kawasaki & Honda
    2015 F3 , Pearl White
    Active Member Moosemanj's Avatar
    Pensacola FL
    I have the R's, they fit on the RT and on my stock F3S seat without any rubbing issues
    Sep 2015
    Missouri
    Quote Originally Posted by Moosemanj View Post
    The traditional R size or the newer smaller R option?
    Thanks, just wanted be sure I order the right one
    Bryant, Arkansas
    Get the "CRUISER" size and you will be happy, also they have a 60 full refund guarantee if you are not happy.
    Fill it with air and sit on it, release air a little at a time until you are sitting in it not on top of it.
    Cruzr Joe
    Pensacola FL
    I have two of these.
    http://www.amazon.com/gp/r.html?R=39...332200_TE_item
    Sep 2011
    Wales , Michigan
    Quote Originally Posted by Hitman5363 View Post
    Mike,
    Suggestions??
    Sorry for the late reply/ I have the first edition R model / it only came in one size.. I used it on my RT before I switched to the F3 n it fits fine w zero rubbing issues ����
    I have the midsize "Cruiser" version. Got it before there was an "R" model. Worked great on my RT with both the OEM seat, and on a Corbin seat. Should work well on any F3 seat configuration.
    A tip: You sit in a Airhawk, and not on it. You have to fiddle around with the air pressure and adjust until you get it just right for you.
