any tips on removing panels and switch installation appreciated.
its pretty easy if you follow the video from lamonster garage..just 3 screws on the side and 3 pull pins..in the video he shows you to install the switch that was real easy. i see you live in maryalnd..im up in harford county if you close by i can give you a hand
:Heres a video i found also:
Fog lights a better and brighter than my headlights.....
...... You Now I need to replace my headlight bulbs.
Just finished install my fog lights.
Everything fit perfect.... Had some issues with the switch sitting properly due to the wires running underneath the panel.....after messing with it all was well.
2015 F3S SE6 You don't stop riding because you get old, you get old because you stop riding
Doing mine this week... Thanks for the vid... What can we use the other tab for where the button goes any ideas? I think Lamont has a lighter in his....
I installed mine tonight and what a nice, nice kit. So glad I returned the stock fog lights and waited for these. So easy to install and a great light. I drove around the neighborhood turning the fog lights off and on to see the difference. Wow what a difference! Thank you, Lamonster!!
I had a 19mm momentary switch there from eBay for a Mo-Door garage door opener. Also a good spot for the heated grip switch.
Received and installed the switch today and love them so far. Didn't get a chance to test them at night but I am pretty sure they will make a huge difference. Thanks lamonster for a great product and outstanding customer service. I took pics of the entire lighting upgrades( bumps kid with led, wiredux daylight running lights and fog light) and now I definitely need to change the headlights' bulbs so waiting on Lamont to recommend and offer the best bulbs out there. Will post pics later
The other built in button is for "heated handlebar grips"
My OH! MY how things have changed since 2008 Spyder
Through the generous help of Lamonster in 2008 (Installation Video plus tips) I installed factory fog lights into my 2008 Spyder - this involved replacing a large factory wiring harness and assembling connectors (inserting pins). The Spyder was completely removed of tupperware - took me two days.
Fast forward to 2016: Installation of Lamonster Garage LED fog lights into my 2015 F3S could not have been simpler - took minutes. True plug and play - no posi-taps required as many other LED plug and play vendors require.
Quality, easy peezy to install, reasonably priced product from Lamonster Garage And Yes these are better than factory fog lights IMHO.
2020 RT Ride Frequent Stay Safe
Aftermarket Aux Light, GPS mounting/wiring, Lamonster Garage Mirror Lock, Lamonster Garage Belt Tensioner
Backrest Home Brew Mod
2008 RS from 2008 through 4/2015, 2015 F3-S from 4/2015 through 9/2020
Now I have to use my factory fogs more than usual so they burn out, and must be replaced with these!
