Results 1 to 18 of 18
    Active Member upsdoctor's Avatar
    Mar 2010
    Derry, NH
    Default Anyone done a BajaRon Shock Adjuster Installation?
    Has anyone installed these? I ordered a set, and I am about to install them on my 2020 RTL. Did you take the front/side tupperware off or the entire frunk? Once installed, is removal of the tupperware required just to make adjustments?
    Bob H - Derry, NH
    2020 Spyder RT Limited - Petrol Metallic Blue
    2010 RT622 Trailer and BRP Hitch
    BRP Vented Touring Windshield, BRP Backrest
    Garmin 590 with BRP Mount
    Fobo TPMS for Spyder and Trailer
    Lidlox, Blue Sea Fuse Box for power distribution
    Ram Ball Mounts for Radar Detector, Cup Holder and Phone Holder
    Sena 20S / SL2 Headsets, Foam Grip Covers, Belt Tensioner
    BAJA Ron Sway Bar and Shock Adjusters, Heli Bars
    Apr 2012
    Florida
    They lost me when it said the shocks have to be removed. Tom
    2020 Petrol Blue Metallic RTL
    Only the shocks hafta be removed to fit the adjusters, no tupperware, and not even the frunk... not unless you WANT to do that to make it easier to access the top shock bolts!
    No need, so I don't ever bother - just remove then disassemble the shock/coil assy (needs a coil spring compressor or friendly tire/spring shop ); fit the adjuster; reassemble & then replace the shock (following the supplied instructions & bits of double-sided sticky tape for the top bolts); and finally adjust them in-situ to return the Spyder to the appropriate height. No need to remove any tupperware or anything but the shocks themselves to fit; no need to remove anything to adjust!
    Aug 2013
    SF Bay Area
    BajaRon has borrowable tools to compress the springs to enable the replacement of the spring stop thing with his adjuster. Took two of us to do it and we were very carful while it was compressed.
    The trick to getting the top bolt out is to raise the bike just enough to let the wheels drop to get better access to them. Use an offset wrench to get at it. Put it in backwards when reassembling.
    2021 F3 Ltd , Magna Red
    Jul 2010
    Las Vegas, NV
    We just did shocks a week ago. Use a 3/8” breaker bar that a bit more than 90degrees. That allows you to get on the forward end of the bolt. Regular socket on the rear side. Follow Ron’s instructions. Use a spent .45 brass to punch the double sided double stick tape. Works great!!
    Call if you get stuck. I’m in the garage all day tomorrow. Joe
    Joe Meyer
    USA
    The spring compressor Ron offers is so good I went ahead and bought mine. Very good piece of equipment meant to work with the smaller coil size on the Spyder.
    https://www.spyderlovers.com/forums/...ferrerid=34189
    h0gr1der
    Nov 2018
    Claremore, Ok.
    unweight the shock to adjust the tensioner. I have mine adjusted up 3 turns.
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
    Mar 2024
    Minnesota
    Hi, I recently purchased a used 2014 Spyder RT for my wife. The front shocks appear to me to have shock adjusters added to them. I attached a couple pictures.
    Do these look like Baja Ron shock adjusters?
    2014 RT SE6 , Black
    Quote Originally Posted by ahtsix View Post
    Those are BajaRon shock adjusters. You should have received a spanner wrench with them.
    Northern Kalifornia
    Ron, I think he bought the trike with the adjusters already on it. Maybe he needs to buy a spanner wrench from you?
    Mar 2024
    Minnesota
    Thanks for identifying the adjusters. I’m new to Spyders.
    Baja Ron, are the spanner wrenches available for sale without buying the entire kit?
    2014 RT SE6 , Black
    Yes, they are. You just need one. But check your tool bag first to be sure you need one. The previous owner should have kept it on the bike.
    Mar 2024
    Minnesota
    Thank you Ron! I called your shop this morning and the wrench is on the the way.
    2014 RT SE6 , Black
    Great! Glad it worked out.
    Apr 2024
    Co Durham, England
    Shock adjustable kit from BajaRon - anyone used it?
    Hi, has anyone fitted a front shock kit for a Spyder RT from BajaRon? If so, how easy was it to fit?
    Last edited by Peter Aawen; 04-11-2024 at 07:08 PM. Reason: Removed Post title after merging into existing thread - both excess threads & post titles mess with Searching! ;-)
    Feb 2017
    I don't mean to sound flippant but it would make sense to ask Ron. He's a member of the forum and no doubt would be pleased to answer your questions.
    2015 Spyder RT-S (Arion) and 2021 RTL Sea to Sky (charming wife)
    Oct 2020
    Arizona
    I had them on my Champagne trike. You need a good spring compressor to install them. I turned them up 1.5 turns if I remember correctly.
    SoFlo
    Quote Originally Posted by Gracie1956 View Post
    Removing front shocks is less drama on a 2014 RT series vs the newer style RT series in my opinion.
    As for removing springs, and reinstalling with preload adjusters, it can be a bit attentive compressing the springs.
    For comparison, I installed preload adjusters on a friends 2021 RT Limited. This was stock springs with adjusters, he weighs about 270 pounds. Certainly an improvement over oem without adjusters.
    For Christmas he bought himself new aftermarket front springs from Martin. I wound up swapping the firmer springs on. I made a simple modification to the preload adjusters allowing them be used with the new springs if needed.
    The firmer springs are an even better upgrade than preload adjuster with stock springs. This is in regards to heavier riders, those that ride two up, or others wanting a more performance oriented setup.
