F3 with Blue Ridge - Modifications to help with turbulence
Howdy,
I've been researching how folks have handled the turbulence from the blue ridge windshield online. From what I've seen you can get the windshield extender or drill holes. My question is about the results of drilling holes. I would rather just modify the shield and not put an extender in my sight line, but I'm not sure if that is actually fixing the issue.
The issue is defined as severe amounts of wind ramping up and landing directly where my eyes are. This causes the helmet (Shoei Neotec) to vibrate at 60+ mph, which in turn affect vision.
I have a 2015 F3-s and am 6'.
Thanks
I gave up...
This doesn't directly address your question, but I looked into all of those "extenders," etc. and just wasn't convinced.
Gave up on the BR. My dealer was nice enough to buy it back from me at wholesale and I got the Madstad...which i LOVE.
I pretty much love all things spyder, but BRP should be just as ashamed of the wind direction from a BR as they also should be of the stock F3 rear shock.
However, that having been said, I've been riding for over 40 years, and the F3 is the "ultimate" riding experience I've ever had...did I say I love it?
F3S Steel Black Metallic
Former owner of '12 RT-S SE-5 and '09 GS SM5
Wind buffeting
I put the Touring MRA x-creen on the 17 inch Gufstasson. I am able to adjust the x-creen to direct wind smoothly over my helmet, quiet and no buffeting. I can also direct the wind more to the vents on my helmet when I need air in my helmet.
i am 5'9" and have a seat cushion that increases my my height by about an inch. I look right over the lip,of the x-creen
My wife has the BR and use the same MRA x-creen and she is 5'6". No turburlance and no complaint from her.
Not really fond of the "look", but I need smooth-quiet wind.
I have had numerous bikes over the years and the wind management on the F3 is poor by comparison. I believe that is has a lot to do with the design of the fairing(s).
I have heard that the 2016 directs the wind better, but real sure about this.
Thanks for the replies. I've considered replacing the windshield, but the BR was so expensive it's a big loss to write off.
Perhaps there is a market for used ones.
The x-creen, did you use the temporary or permanent install? Does it seem like it will last and stay clear and scratch free?
I started with the temporary install, but the permanent install looks so much better that I ended up drilling the holes and installing it. I'd say you might want to save yourself the money and just go permanent. Or I can sell you some clamps for cheap
We both went with the tour because it's wider and seems to fit the BR better. I've had it on for about a year and it's held up very well.
We now have His and Hers Spyders!
Current Spyder: White 2015 F3-S SE6
His Spyder: White 2015 F3 SE6
Previous Spyder: 2012 RT Limited SE5 -- 30,300 miles
Previous rides: Kawasaki & Honda
Thanks!
The best and only modification that will absolutely cure the buffeting is to carefully remove the Blue ridge place it on a flat level working surface, take a 20 oz hammer and smash it to little bits and then install an F4......
mark
Bullies are sad pathetic People
Possible $$$ saving alternative
pludn,
You might look at this post by Machinegunner: http://www.spyderlovers.com/forums/s...ght=blue+ridge from some time ago. Based on that idea I did add some spacers under the back of my Blue Ridge to tilt the windshield forward. It did help me but I am a few inches shorter that you indicated. It still did not put the air over my passenger so I just installed an F4 windshield.
Enjoy the Ryde ,
Lee
Lee & Karen
2022 F3 Limited - Matte Black
F4 Customs Windshield, Lamonster Driver Backrest,
Lamonster Fog Lights, Wrap My SPYDER Tank Protector,
Lumina Trailer
I sold my Blue Ridge on here and got the Madstad, that I truly love.....
220,000 Mile Spyder Ryder, IBA Premier member #59352, Saddlesore 1000 (11), Bun Burner 1500 (3), Saddlesore 2000 (2), Bun Burner Gold, MILEEATER SILVER
SpyderLovers Sponsor
Go check out the Laminar Lip they are good and work well
on any windshield I think it's www.laminarlip.com
Howdy,
Thanks
mark
The X-creen Tour model completely eliminates the buffeting on the blue ridge. AND it's your cheapest option.
rick
rick
I have to disagree.. Mine still buffeted so bad it would activate my Sena headset....... It was money that I should have used towards my F4 shield that will eliminate the head banging
mark
Thanks for all the alternatives folks. It's much appreciated.
I am slightly intrigued by the spacers and cutting a slot in the bottom. That seems to be a 20$ fix if it works. The spacers create a better deflection and the cut allows more air to hit you and the engine for cooling while also cutting down the top current?
Disappointed with F3 Madstad turbulence
We have a Madstad on our 2009 RS and it has been good.
I have just fitted a Madstad to our F3 and I don't feel that it works as well, especially for the pillion rider. I often ride pillion and the vicious turbulence shakes my head so badly at any sort of speed above 45mph that my vision is blurred, much like looking in a vibrating mirror.
Windscreen adjustments do not help. I am emailing Madstad to see if they have a solution, otherwise we will exercise their 60 day guarantee.
I still have the BR we bought while waiting for the madstad, so might even try a screen option for that. It is noticeably better around town.
What speeds do you ride at?
Originally Posted by jcthorne
If you already have the Blue Ridge, you might try the Gustafsson replacement shield for it. To me its the best of all the options. The brackets look and work as OEM and the shield actually does what you think it should.
What speeds do you normally ride? We do 75mph to 85mph two up.
Do you carry a pillion - what is it like for the pillion? I regularly ride behind my wife at those speeds, and with the Madstad at anything over 45mph my vision is blurred.
The Madstad on our RS is much better.
I liked the F4 shield but their brackets look like an erector set hodge podge. Just could not have that on my bike.
Agreed. Or, as someone just said over the phone, it looks like sailing a boat down the highway.
However, if it's the only thing that works, we might have to do it!
I have the BR and the tour x-creen extender. Solved the problem completely for me. I dont like the after market ones, to big and dorky looking. Its like a big wind sail going down the highway. x-creen is adjustable. I used the clamps, So that I can take it off if I want too. Has held up well, no scratching. I check the clamps every so often to make sure they are tight but have never come even slightly loose.
I also have the BR and have just installed the X-Creen Tourer.
Solved the buffetting and vibration of the helmet and also cut out the noise on the right hand side of the helmet.
Money well spent.
Windshield for the F3
Here is what one of the riders that has a F4 Customs windshield for his F3 had to say.
A big thanks to Don at F4 Customs. I installed the F4 Customs 32" windshield Saturday. We rode a couple of hundred miles yesterday and today. (The weather was great here in the deep south this weekend.) The windshield just puts the air-flow over my wife's helmet in the upper position. She says it "makes a big difference" at interstate speeds compared to the blue ridge that was previously on the F3. Hope this will help anyone that has similar needs for a passenger.
Lee
F4 Customs, Inc.
"The Motorcycle Windshield Folks"
941-347-7496
sales@f4customs.com
<a href='http://www.spyderlovers.com/adserver/www/delivery/ck.php?zoneid=22' target='_blank'><img src='http://www.spyderlovers.com/adserver/www/delivery/avw.php?zoneid=22&cb=567846784' border='0' alt='' /></a>
I normally ride 75 to 80 and am very pleased. I only rarely have a passenger and then only for short hops. My wife has her own RT.
Look nice
Hello can you tell where you bought this windshield and around how much you spend
Thanks
[/QUOTE]
