Results 1 to 12 of 12
    Aug 2015
    Cleveland, GA
    Default TricLED 3rd/4th brake lights
    I'm in the middle of installing the 3/4th brake lights from TricLED.
    Question:
    Each LED strip attaches permanently to one of two different body panels.
    The two LED strips are wired together and do not appear to be simple plug-and-play separable.
    Specifically, the two black ground wires are crimped together into a single plug; the red wires are connected in a small gray junction block with orange press-down levers (are these wires able to be disconnected by prying up on the orange levers, or is that a one-time permanent union?)
    This arrangement makes the two main rear body panels Siamesed by this wiring so if you remove the one upper (painted) panel that fits right below the trunk lid, you must also remove the lower black fender panel and keep these two bulky pieces together.
    Do folk cut the red and black wires and connect/disconnect with reusable Posi-tap connectors?
    What am I missing here? I feel like I'm suffering a cranio-rectal inversion.
    Pete Tamblyn
    Cleveland, GA
    2020 F3 Limited (black)
    Time Out XL1800 cargo trailer
    2019 Royal Enfield 650 Interceptor
    2018 Kawasaki Versys-X 300
    2013 ST (sold)
    2015 F3-S SOLD
    2014 RT-Limited (cognac) SOLD
    Yeah ...
    They're left dangling together, by a shared umbilical cord.
    I hate to try and explain how I ended up supporting both the top panel, and the rear fender at the same time...
    I ended up using rubber tie-down straps looped up through the top trunk supports, to hold the top panel...
    ...and I built a raised platform out of milk crates, to hold the fender...
    Which left me almost NO room in which to work!
    Active Member mustangbob's Avatar
    Jun 2013
    jackson, michigan, USA
    When I installed mine I cut wires and used positaps, make its much easier.
    2012 RTS SE5, GT stripes, belt guard, hmt brake light, lower vent heat deflector, driver foot boards, Corbin seat, RH vent covers
    Aug 2015
    Cleveland, GA
    Default posi-taps to the rescue
    Quote Originally Posted by mustangbob View Post
    Strange the directions make absolutely no mention of this dilemma................
    .......or does no one else find having the panels hooked together by the wiring harness an issue?
    Pete Tamblyn
    Cleveland, GA
    2013 ST (sold)
    2015 F3-S SOLD
    Active Member PatriotRider's Avatar
    Sep 2015
    Metairie, LA suburb New Orleans
    Cool
    I use waterproof jst connectors...cheap from china
    http://www.ebay.com/itm/30-Pairs-Wat...qIAAOSwSdZWcSA-
    or posi's or crimp on spade or bullet connectors
    eezee peezee
    let's ride safe & be careful out there,
    Mike in Nawlins'
    2014 Black SE6 Limited "Charlotte"
    New Orleans Ride Captain
    Patriot Guard Riders
    Active Member Old Prof's Avatar
    Sep 2015
    Columbus, Ohio
    Default Installation video?
    Several folks have mentioned that the Tricled website has installation videos. While I know my memory is going, guess my eyesight is too. I've looked and not found any. Help?
    2016 RTS SE6
    '64 Honda CA95 "Dream"
    Invalid Emails
    Feb 2016
    Dublin, OH
    Quote Originally Posted by Old Prof View Post
    Hi, our website don't have installation video. However, we uploaded some installation video into YouTube. I hope this helps.
    Aug 2015
    Cleveland, GA
    Default link to TricLED 3/4 brake LED installation
    [QUOTE=Cindy-TricLED;1103406]Hi, our website don't have installation video.
    Cindy:
    A preliminary search on YouTube didn't turn up an installation instruction video.
    Could you provide a link please?
    Thanks,
    Pete
    Pete Tamblyn
    Cleveland, GA
    2013 ST (sold)
    2015 F3-S SOLD
    Sep 2015
    Columbus, Ohio
    Default Listing would be helpful
    Quote Originally Posted by Cindy-TricLED View Post
    It would be VERY helpful to have a list of links to these uploaded videos. Your company has an excellent reputation for helping folks installing/maintaining your products....this list would only serve to enhance that reputation. Just sayin.
    2016 RTS SE6
    Aug 2015
    Cleveland, GA
    Default just cut the wires and get on with it!
    Bob:
    You've got the solution. Posi-taps to the rescue.
    I got my installation finished up, and added a pair of red brake light flasher pods on either side of the license plate.
    Pete Tamblyn
    Cleveland, GA
    2013 ST (sold)
    2015 F3-S SOLD
    Invalid Emails
    Feb 2016
    Dublin, OH
    Thank you for your suggestion Old Prof.
    We are looking into this and to improve the process.
    Very Active Member bluestratos's Avatar
    Jun 2011
    Lynden, WA
    I hope to be taking the parts off again this weekend now that my mini disconnects have arrived from Amazon. I have to say I was more than surprised when I discovered that the two panels cannot be separated for maintenance purposes.
    While it is an easy fix, the correct connectors are worth about .25 cents each and will take no time to install when the harness is being wired up.
