2014 Can Am Spyder RT-S SE6 Front Wheel Vibrating Up and Down when Braking or Reverse
2014 Can Am Spyder RTS front left wheel and cowling vibrates up and down when braking and in verse. I'm thinking it the rotor causing this problem. Any suggestion.
I had a friend that had the same problem One of the rotors was wrapped replaced it and put new pads on both front wheels
SUGGESTION
I can think of at least 20 reasons why...................However if you give more info it will help narrow it down....Think of what a mechanic would ask you about when this began .................Mike
This post requires you to click the Thanks button to read this content.
this posting has been vetted, scrubbed and endorsed by the committee for postings
Ozzie Ozzie Ozzie
Who sets the 'Require Thanks to see post content' button on their posts?!
Doing that on purpose so a potential reader MUST click thanks to see what you contributed to the Thread & Forum is a bloody annoying way of boosting the number of 'thanks' you might get and pretty much just a really low act that almost certainly guarantees I won't bother reading any of those posts.....
But since it was most likely triggered by accident or has been set as a default & just carried on, then maybe the two prior posters above could modify your posts so that ALL others can see what you wanted to contribute?
As for the OP, it does sound like it's a warped disc, but Blueknight has hit the nail on the head - what more can you tell us to help narrow it down a bit?
I'm clicking "Thanks" and "Like" on your post, because it's true!
And nobody forced me to do it!
Ozzie Ozzie Ozzie
Thanks Bob!
happy old fart
Don't know. ..!!
Not knowing the whole story but willing to venture a guess, one must remember there are a few shock absobers out there that did not perform well. The disc can also be a possibility and many more as mike stated. Suggest a full front end checkup....
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
Why guess
Why guess, it's a 2014 and should still be on warranty. Take it in to your Dealer and have it checked out.
Tri-Axis Chrome Handlebars
Sena SM10 BT Dongle
Double USB Port/Volt meter
LaMonster Magic Mirrors
BajaRon Swaybar
HALO Skid Plate
Shorty Antenna
LaMonster Cat Delete
Akrapovic Muffler
FOBO2 TPMS
Rear Trunk Rack
Bruce Erickson
Chilliwack, BC
Canada
2014 RTS-SE6 - Cognac
