Results 1 to 13 of 13
    GOS member (Girls On Spyders) ruthie's Avatar
    Feb 2011
    Collinsville, Mississippi
    Default Trailer Hitch from Big Bike Parts
    Does anyone have the trailer hitch that Big Bike Parts sell? If so what is the pro and con of this hitch?
    2014 RT SE6 Limited
    rYding Safe = Having Fun
    Ruthie
    Jul 2011
    Mitchell, Ontario, Canada
    Quote Originally Posted by ruthie View Post
    Put one on my ST. Will also fit on RT or RS. Works well for me.
    Cheaper to buy. Mounts the same.
    2018 F3 LIMITED
    Oct 2015
    Moody, Texas
    Default Big Bike Parts
    It looks great and installed in about 15 minutes. My son was reading the install instructions and we
    while he was doing that I went into the shop , had it installed by the time he was done reading.
    The only thing I would have liked, is the bolts was not black. little paint and you are good to go.
    Very Active Member IGETAROUND's Avatar
    Oct 2011
    Kalamazoo, Mi
    Have one on my bike; other than not impressed with the quality of their powder coating works fine.
    All the great movements in the world began with a cup of coffee!
    2018 F3-T
    My mods: Can am Trailer hitch, USB and 12 volt power outlets, Gustason windshield, Bead rider seat cushion, battery harness for electric gear and battery tender, Time out trailer.
    2018 F3-T , Pearl White
    Nov 2015
    Piqua Ohio
    Default Hitch
    I just installed the same on my 2012 RTS looks good and was easy to to put on.
    Member Dodgedad's Avatar
    Mar 2015
    Canada
    Does it affect your warranty if you buy a hitch thats not made by BRP. I was reading in their litature that theirs is the only one warranty approved
    Nov 2013
    Oro Valley Arizona
    Quote Originally Posted by Dodgedad View Post
    That is correct! The mounting is different I believe. It does not incorporate the axle for mounting. Correct me if I am wrong.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Idaho
    Only if you have a failure in your Spyder that can be shown to have been caused by the use of a non-BRP hitch. That would be pretty nigh impossible to prove. So no, don't worry about your warranty being impacted.
    2014 Copper RTS
    Default HITCH MOUNTING
    Quote Originally Posted by jaherbst View Post
    Jack
    ...Sorry Jack you are wrong, all the Hitches for Spyders involve the axel either directly ( under the Axel nut ) or indirectly ( bolt thru the axel ).......However the new F-3 hitch from Bushtec bolts directly to the Swingarm. .......Mike
    Nov 2013
    Oro Valley Arizona
    Thanks Mike, I like the axel mount better, (axel through and part of the mount). I would guess that's why the warranty only with the OEM hitch. On the other hand I have not heard of any problems with the after market hitch so far. Can anyone out there add to this.
    Jack
    2015 BMW R1200R LC
    Jul 2015
    Dorr, michigan
    Love mine, had zero problems with it, very easy to put on, and towed my bunkhouse camper over 4,000 miles with it last year.
    Be aware that if you have the Big Bike trailer hitch and the Big Bike mudflap extender
    you may have clearance problems.
    When I hit a pothole the swing arm dropped down, the mudflap extender popped over the hitch, and it cracked the back fender on the bike and broke the extender.
    I replaced the fender, received a new extender for free, and modified it so I wouldn't have problems again.
    You would think that both being made by the same company they would work together.
    2020 RT Limited , Petrol Blue
    May 2013
    Stanton, ca
    The Big Bike trailer hitch bolts on exactly the same as the BRP hitch. Long bolt through the axel.
    Bob
    Very Active Member zuni's Avatar
    Mar 2014
    JAX FL
    We have had it on our RTS for over a year with no ill effects. Replaced the supplied bolts with black. Had a little issue with the bolts wanting to loosen up but a bit of removable loctite took care of that. The hitch is also available from SpyderLovers vendor Value Accessories at a discount.
    CJ JAX
