Results 1 to 6 of 6
    Nov 2015
    St. Louis, MO
    Angry vibration issues
    I have a 2013 RT Limited. I experience a lot of vibration at 50-55 mph. Any ideas on how to correct this. I
    Nov 2013
    Central Texas
    Correct belt adjustment and a belt tensioner. My '13 RTL vibrated like crazy. I installed the SmoothSpyder belt tensioner almost 3 years ago, and it really does a great job of reducing the belt's harmonic vibration. It also makes a big difference as to what gear you are in and what the RPM's are. At 50-55, you should still be in second. The 998's like to be wound up.
    The 998's like 5500 rpms or so for shift point and running. That means no fifth gear until you hit 60 - 65 miles per hour in most cases.
    Default THIS WORKS
    Quote Originally Posted by monasrtlimited View Post
    Less belt tension.............see Idaho Mountain Spyders ...Thread........Mike
    Oct 2011
    Kalamazoo, Mi
    If you have not had it in to the dealer recently to check the tension that's the first step if the tension is correct then higher RPM's for shift point and don't lugg the engine stay above 5500 rpm for your shift points
    2018 F3-T
    2018 F3-T , Pearl White
    Thinks out loud
    Apr 2012
    Thumbs up
