Results 1 to 5 of 5
    Columbus, Indiana USA
    Default Trailer Wiring Adapter for Non-CamAm Trailer
    I have a non-CanAm trailer that I would like to pull behind my 2012 Spyder RT but am having trouble finding a trailer wiring adapter to go from the CanAm 4-pole square-shaped plug to a standard 4-pole flat plug on my trailer. I was trying to avoid having to make a special adapter, but I can't find a standard adapter available for purchase.
    This is the CanAm Spyder plug (approximately 1/2" square).
    This plug on my trailer.
    I
    If anyone know of a standard adapter that might be available, please let me know.
    Jul 2011
    Mitchell, Ontario, Canada
    The fastest and cheapest solution is to cut the trailer 4 flat in half. Put the 2 halfs together to make a homemade square 4.
    Or I would recommend going to a well stocked autoparts store or a trailer supply store then buy a matching square 4 and flat 4 and wire up an adapter. The wire colors will match on both plugs so easy to figure out.
    2018 F3 LIMITED
    Mar 2012
    Spokane, WA
    What I did was buy a set of each pig tail (only way to buy them that I know of) and connect them. Easy pezzy. I used butt connectors, heat shrink tube each wire and then put in large heat shrink tube. Has worked well for 3 years. Took about a 1/2 an hour.
    Active Member randyandsandy74's Avatar
    May 2014
    Idaho
    Default trailer
    Try amazon and type in 4flat to 4square trailer adapters
    Sep 2014
    USA
    Those square plugs can be bought .. Del City,Amazon and others. You will have to make up a adapter.. I had to do the same for the 622 trailer to my car flat.
    http://www.delcity.net/store/4!Way-S...92.h_85143.t_1
Tags for this Thread
