Results 1 to 14 of 14
    Active Member SpyderCruiser's Avatar
    Nov 2014
    NJ
    Exclamation Anyone see this issue yet?
    Was installing some Farkles today and noticed this.
    Appears to be leaking where the water pump joins the motor. Found one screw slightly loose, unable to get to the screw behind the hose to try that one. Did have to add some coolant last season. Cleaned the area up and will monitor it this season.
    Guess if it continues, it will have to go back to the dealer as it is in warranty. Anyone seen this before and what the issue is?
    2015 RTL , Red
    Default No
    Not a obvious place but worth looking into. Have not seen any mention of it so may be more out there just not noticed.... thanks for the heads up...
    Apr 2012
    Northglenn Colorado
    yep, looks like the same leak I had on the F3. Replacement if under warranty. If not just watch the coolant level
    Oct 2014
    Lisbon, CT
    I noticed a small coolant leak on the floor of the garage while moving the bike last week. I bet it is coming from this same area. thank you for the info and pictures!
    United States
    Appreciate the heads up. The 1330 is an awesome engine, but there will be some issues start showing up. Looks like this is one we all will need to look for.
    Dec 2014
    Lee's Summit, MO
    I just made an appointment for a coolant leak on my '14 RTL. Had a big puddle under the right side behind the a-frame.
    Active Member Cleg's Avatar
    Apr 2012
    Queensbury, NY
    Default Leak
    Thanks for the post and pics. My '15 RT-S SS has had a small puddle on the floor AFTER only short movement. Maybe one in the same. I haven't seen any puddles after longer rides but when it is at the dealer, I'll have that checked. This is a great avenue to garner info on all aspects of the Spyder...THANKS!
    washington state
    Who ever have the same issue it should be address to BRP and they should take care of it. Loose bolt is a production fault and must be dealt with in a professional way.
    Nov 2014
    NJ
    Smile
    I am hopeful that the bolt that I tightened may have fixed it. Drove 55 miles today and checked after the ride and no coolant leak in that area. The bolt was only loose by 3/4 of a turn.
    2015 RTL , Red
    Dec 2014
    Lee's Summit, MO
    Quote Originally Posted by SpyderCruiser View Post
    Quote Originally Posted by kngfsh27 View Post
    Took my Spyder to the dealer this morning. Leaking in the same area. Have a new water pump on order. Hopefully be in Friday so I can get "27" back on Saturday. Glad for warranty. Also glad it happened over the winter and not during nice weather or during a trip.
    N. Va
    When you tighten the bolts, are you puling the bolt all the way out then adding something like loctite threadlocker, then retorquing the bolt?
    Jerry
    Vermont
    Thanks for letting us know and keep us posted. Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Nov 2014
    NJ
    Quote Originally Posted by spacetiger View Post
    Jerry
    Jerry,
    It is under warranty so just gave the bolt some tightening. If it leaks again it is going back to the dealer under warranty.
    2015 RTL , Red
    Jul 2015
    Saratoga New York
    Default Thanks...
    Now I need to take a look at my '15 RTS, noticed a wet spot on the shop floor and thought it was from the car. Maybe it's going in for the 3000 mi service sooner then later.
