Results 1 to 25 of 31
    Invalid Emails
    Oct 2015
    Deland, FL
    Default What if seat doesn't release to open and fuel?
    Have you thought about what would happen if your switch would not open the seat release and you needed gas? I asked the dealer about this. He said to just pull up hard and something will let go and we will fix it when you get back. Figured there had to be a better way. So, I took a length of fishing line(strong and thin) and created a loop to put it around the mechanism that has to move back to let it open. You can see this by working your key to open and watch the cable connection. On the other end, I tied a small key ring that I can pull on. I put the ring up in the glove box. you can barely see the fishing line but if ever would not open you simply open the glove box, move the line down run along the inside of the seat and pull the ring. Now you are open and can get fuel without ripping your seat up. Not sure why they even have it lock. Thinking of just taking out the connection and letting the seat sit without locking in. Don't see an advantage to the lock which if they want to steal your gas they will just rip open the seat. Just some food for thought.
    Active Member Mick N's Avatar
    Jul 2015
    Dublin Ohio
    Thanks for the tip!
    2012 Spyder RT-S SE5 Blue
    Can Am: Floorboards, Tri-Axis handlebars, Comfort Seat, Front/Side/Rear cargo travel bags
    Vendors: Air Hawk2 seat air cushion, Adjustable Side Window Deflectors, slip-on grip covers, RAM GPS mount & a short RAM socket arm... with a bicycle handlebar bell mounted to it - a carryover from my 2-wheeling days, it was great for getting your ridng buddy's attention when stopped at a traffic light
    <img src=http://www.spyderlovers.com/forums/signaturepics/sigpic19190_7.gif border=0 alt= />
    Good tip!
    But...
    Active Member PatriotRider's Avatar
    Sep 2015
    Metairie, LA suburb New Orleans
    Cool kinda sorta a (partial) fix
    let's ride safe & be careful out there,
    Mike in Nawlins'
    2014 Black SE6 Limited "Charlotte"
    New Orleans Ride Captain
    Patriot Guard Riders
    Here's my version made with wire. After I took this pic I bent the wire tighter around the latch arm. I can pull the end of the seat out just far enough to reach and grab the loop.
    Very Active Member JerryB's Avatar
    May 2014
    Beaverton, Oregon
    Hi Bobleach45,
    Re: Thinking of just taking out the connection and letting the seat sit without locking in.
    This what I did. I really do not see a downside.
    Jerry Baumchen
    'I'll never forget what's her name.'
    'Things are more like they are now than they ever have been before.' Dwight Eisenhower
    2008 GS SE-5
    Quote Originally Posted by JerryB View Post
    Hi Bobleach45,
    Jerry Baumchen
    Just facilitates someone siphoning the gas out of your tank, or stealing your tool kit, but other than that, not much. Under the seat is a convenient place to carry the adjusting wrench for the Tri Axis handlebar while you're tweaking its position.
    Default STEALING STUFF
    .These would be my last TWO worries ........I was an LEO for 37 years and never heard of GAS being stolen from a Motorcycle.....and as far as the tools go....How many posts have we seen about people claiming they bought a Spyder for $ 30,000 and didn't get any tools .....Because they couldn't find them and they owned the Bike ....Mike
    Very Active Member 4 MARIE's Avatar
    Apr 2014
    Beloit Kansas
    they could take my whiz-bang toolkit. I think the straps that held it in place are more valuable
    as helmet strap extenders enabling the use of the virtually nonfunctional helmet hooks.
    As someone previously stated in some seat install chats, the seat doesn't really need to latch, just use the
    pin to "locate".
    Flatlander, Navy Veteran, Widower
    Loved my 2014 RTS SE6 Pearl white
    but have a new love now,
    my 2017 RTS SE6 Champagne metallic (Champ)
    May 2014
    Beaverton, Oregon
    Hi IdahoMtnSpyder,
    Re: a convenient place to carry the adjusting wrench for the Tri Axis handlebar
    Please note that I ride an '08.
    Jerry Baumchen
    PS) They could get a grand total of about $15 worth of gas, if it was completely full. Not really worth taking the risk for that little $$$$$$ IMO.
    2008 GS SE-5
    Very Active Member pitzerwm's Avatar
    Nov 2014
    TriCities, WA
    I tried just disabling lock, but my gas shock is too strong and the seat will come up if you aren't sitting on it. The fishing line/wire is the trick I think, cutting the seat so that iut folds back is even better and BlueKnight's "door" is clever too.
    One of the hardest decisions you'll ever face in life is choosing whether to walk away or try harder.
    Jun 2014
    People's Republic of NY
    Why would anyone steal that superdopper imitation tool kit
    committee for postings
    Jun 2014
    If you are one of the few folks that use the helmet hooks under the seat ; not being able to latch it down, could be an issue for you...
    Nov 2013
    Oro Valley Arizona
    You are spot on Mike. I try to not worry about what could happen and think about what is happening now.
    ​Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    RT-S PE#0060 Gordy's Avatar
    neepawa manitoba ca
    my release cable broke a long time ago so I filed a taper on the other side of the pin that goes into the latch assembly,The latch still holds but just have to give a pull up and it unlatches
    Nov 2015
    Nebraska
    Default Tool
    I made a tool that works great for seat and fronke.
    Nov 2015
    Nebraska
    Default Pics
    How do you post pics ?
    Quote Originally Posted by Marr View Post
    Very Active Member wmh9680's Avatar
    Nov 2015
    Tinley Park, Il
    Quote Originally Posted by pitzerwm View Post
    At one point I took the shock off and kept a small length of pvc under the seat to prop the seat up.
    2014 RT Limited Matte Silver, Belt Guard, RT Dash Mount, Show Chrome Can-Am Spyder RT Passenger Arm Rest, Show Chrome Full Size Brake Pedal,Best shop manual, Spyder keycover with hole, Utopia drivers backrest, Showchrome trailor hitch, ShowChrome Acc Trailer Acc Rack, 2014 CA Spyder RT-RTS Master Collection-HDSv5, Airhawk Cushion, Spyderpops bumpskid, Ipod cable, Led lights, Driver Hiway pegs, Shorty Antenna, Pin Striping, ECU flash, TriAx adjustible handlebars,
    Will it ever stop--NO
    Very Active Member sealfloorboards's Avatar
    Aug 2010
    Newberg, Or.
    My seat latch got stuck too. I took it to ProCaliber, in Vancouver, Wa. They got it opened and, together, we decided to disable the latch with a zip tie. Works great and I just have to lift the seat for gas.
    Ride in comfort,
    John
    Greenville Tx
    You dont have to disable the latch, Just unscrew the post from under the seat and put it in your super dooper tool kit.
    2017 F3 Limited
    Greenville Tx
    You could then say You have an In Plain Sight Spyder seat.
    2017 F3 Limited
    Default removing the post
    Quote Originally Posted by AY4B View Post
    After you do this and discover lots of scratches etc. on the back of the gas tank you will wish you didn't remove that post .... the seat WILL move forward / backward when you are riding it .... that POST prevents that movement ..... Mike
