Results 1 to 16 of 16
Thread: Tire Question
    Registered Users sypderrobinson134's Avatar
    Jun 2014
    St. James, Mo
    Default Tire Question
    So I know that the day is going to come that i need to get new tires for the spyder. It's not here yet and with hope won't be here this season. However, my question is this. i have a 2012 rs and wanted to know roughly what I could look to pay for 3 new tires installed. Now I understand dealer prices might be a little different but we got to talking about it and it made me curious what everyone's experience was with it.
    Default Don't know. ..!!
    Do my own work but you will find that your back tire will be gone long before the fronts. I have the same year and model and ryde hard and mostly double up and got 22,000 miles on the back and over 30 on the fronts.Dealer rates and times may vary and it will also depend on how much you can help. removing the front wheels is a breeze and then all they can charge is for the mounting. The rear is a bit more of a challenge.
    ​2012 RS sm5
    About $300 tire and install on the rear. About $300 tires and install on the front.
    Mar 2015
    Stony Mtn, Manitoba
    Angry
    Try $800 out the door FOR ONE REAR TIRE at Winnipeg's only Spyder rip-off shop.
    I took the wheel to the local Harley dealer, $25 installation, $150 delivered for a Kenda tire. Still had to go the dealer who charged me $200 to R&R the wheel.
    So it really depends on the scruples of the local dealer.
    Those who can't, criticize those who do.
    2011 Spyder RSS SM5 - Bought new Apr 2015
    Jun 2014
    St. James, Mo
    Thanks for the help guys. I think I"m a ways off like I said I've only got 12K miles so I'm looking for a while before I have to change tires but it's good to know what I"m looking at.
    Nov 2013
    Oro Valley Arizona
    Check the search button. There are 2,003,236 different nopinions on there. In fact there are opinions on there for which no questions have ever been asked. The opinion meter on this site is stuck on overload.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Very Active Member PistonBlown's Avatar
    Jan 2013
    Christchurch, New Zealand
    My approach for the rear wheel:
    1. Watch Lamonts rear wheel removal video in the DIY section (how to remove it without changing the belt alignment/tension)
    2. Remove rear wheel and take rear wheel to local tire shop (car tire places should be able to do it).
    3. Put rear tire back on Spyder.
    The fitting is normally included in the cost of tire, if your supplying the tire then it's probably $20 or so to fit.
    RT-S PE#0060 Gordy's Avatar
    neepawa manitoba ca
    Quote Originally Posted by isthatahemi View Post
    last spring I needed new front tires on my rts was in walmart and they were selling off their winter tires I got 2 175/65/14 tires for $26,00 each they had a none aggressive tread took the wheels off and had walmart instal and balance them for under $100.00 tax included, used them all summer and very satisfied .I am going to replace rear tire again this spring getting a 215/60/15 general $98.00 I always remove wheel myself so will only pay for installing on rim ,do my own balancing on rear
    Aug 2015
    canada
    Default Bigal55
    Hi my name is al child's my wife and I live in wpg . we both drive 2009 rs spyders I am retired and always looking for ridding buddies if interested give me a call 204 795 2895 hope to hear from ya.
    Active Member TechnoTherapist's Avatar
    Jan 2016
    Madison, Alabama
    This past Saturday I paid $179 for a new rear tire and another $80 for install (1hr labor) at my dealership. Not sure how some of you are getting 20+ thousand miles... I start off and ride like a grandpa and only got 7500 miles out of my rear tire. Fronts still look almost new. Rear was getting completely bald in patches, right in the center of the tire.
    I've found rear tires on eBay for around $140.
    Cy
    Cy
    1. Why do they call you Cy? It's short for Sexy Cyclops
    2. What happened to your eye? Space Monkeys happened.
    3. What do you ride? Black 2015 Cam Am Spyder RS
    Default IT's BECAUSE
    Quote Originally Posted by TechnoTherapist View Post
    Cy
    ...............We aren't driving with " CRAPENDA " ( Kenda ) tires anymore .......Mike
    Active Member whitjim10's Avatar
    Jan 2013
    greenville, sc
    I bought 2 front tires took the wheels off and had discount tire mount and balance them for 32.00
    It completely depends upon what tire you decide to purchase...
    (And if your dealer is willing to mount a non-brp tire)
    I'm running an automotive tire out back: paid $81 dollars for it, and $50 for the installation.
    I've always had good luck with brp front tires, so I might just stay with them...
    ...or I might not!
    Dec 2015
    Edna, Texas
    Cy
    We had the same thing happen to us and the dealer lowered the pressure by three pounds. Said the cause of wear was because how the tire inflates at high speeds. After deflating tire got better wear on the rear tire.
    Active Member Tx web rider's Avatar
    Jun 2011
    Aransas Pass Texas
    Default tires
    pick up 3 tires from discount tire remove the front ones take them in to discount when they get them in the mount them free
    i use the local automotive tire place to change my rear i pull the tire and remove the center hub and no issues $10 done
    tires will run around 80 each
    Very Active Member coz's Avatar
    May 2011
    cincinnati, ohio
    Default Indy shop
    Any good independent bike shop can do your rear tire. Last year I bought a kuhmo off the inter web , and had my Indy install it. The whole deal was around 150.
    it was fun while it lasted.
