Page 1 of 2 12 LastLast
Results 1 to 25 of 38
    Oct 2015
    Bedford Virginia
    Default Couple questions for you
    Good morning everyone!
    I have a 2015 RTS with semi automatic...
    First question: If you should need to manually downshift-Do you back off on the throttle?
    Question #2 -What cleaners do you use on the Spyder body and the windshield.
    Some of the products that the shops recommend just seem to be ridiculously expensive to me.????
    Thanks for your help.
    Hope everyone has a great weekend.
    Don
    Jun 2014
    People's Republic of NY
    hi
    no you don't back off when downshifting the SE6.
    Mar 2015
    Brockport, NY
    Default Food for thought
    I'm fairly recent to the spyder scene also, and initially found I wanted to downshift. Out of habit I would roll off the throttle a bit for a smoother shift, but then found myself just letting the spyder do the down shifting for me. I typically only shift if it's a sudden slowdown. As for cleaners, your right there are tons of them out there and I recently found one from Maguires called white wax, I have a pearl white rts, and I am pretty happy with it. I believe it was $10 for a tube of it and I think it will get me a seasons worth of waxing. As for the windshield, and all other plastic shield pieces, I use plexo spray cleaner after thoroughly finish g all the bugs off so not to scratch. Just make sure you do not use an ammonia based glass cleaner on the plastic lens pieces it will cause them to haze.
    2014 RT-S Pearl White
    Active Member Sccar's Avatar
    Mar 2015
    East Texas
    Default Question#2
    I use Honda polish. ....about $5.50 a can.
    2015 F3S SE6
    You don't stop riding because you get old, you get old because you stop riding
    2015 F3s , Orange/black
    Invalid Emails
    Jun 2014
    round rock texas
    Default Plastiwax
    Quote Originally Posted by Don K View Post
    Don
    Mgueires makes "PlastX" which I use on windsheild and all lights with plastic cover, shines ,cleans and polishes..Just my choice..
    The computer will handle the throttle for you during any shifting activity...
    Cleaning?
    In the past; I've used Meguiars quick detailer, but I just got some of the cleaner that Lamont sell... I haven't cracked it open yet, but will be giving the bike a thorough cleaning once the Season gets a serious start to it/
    (Thanks, Joe!)
    Nov 2013
    Oro Valley Arizona
    Good old Pledge works wonders on Windshield and Body. Can be found everywhere and not expensive. I have used this to clean cars, motorcycles, airplanes, trucks and boats. Terrific on plexiglass windshields. (be sure to use a clean cloth) Will also work well on your glasses and face shields on your helmut.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    May 2013
    Indiana
    Quote Originally Posted by jaherbst View Post
    Good old Pledge works wonders on Windshield and Body. Can be found everywhere and not expensive.Jack
    +1
    2021 Marsala Red Metallic RT Limited
    Member Smutt's Avatar
    Nov 2015
    Nl Canada
    Been using Pledge for years on our Goldwing and will be using it on our new Rt Limited.
    2015 RT Limited
    Show Chrome Drivers Backrest
    Show Chrome Passenger Armrest
    Show Chrome trunk Rack
    Ron's Shock Adjusters
    Ron's Sway Bar
    BRP Trailer Hitch
    CB Communications System
    Spyderpop's Bump-Skid
    Spyderpop's Belt Guard
    JT's Rear Fender
    Default HOWEVER
    Jack
    ...................But definitely NOT on the Windshield........It will build up and you will have to remove it with something much stronger............Also NEVER use paper I don't care what F-4 says....Here's a scenario, you have an F-4, you are washing and using PAPER.....your better-half is washing Hers SHE doesn't have an F-4, but She copies you and uses PAPER.................AND SCRATCHES UP HER WINDSHIELD........if you think I'm being ridiculous, I'm OK with that......jmho.....Mike
    Jan 2016
    Mandan, North Dakota
    Default Bugs
    What does a person use to get dryed bugs off?
    Vermont
    Shifting............... let the spyder downshift for you, unless you have to shift down for something unexpected.
    Cleaning spyder................ I use Blue Coral wash/wax concentrate: Cleans & Shines in one step Fortified with Carnauba Wax, Blue Coral Wash/Wax is fortified with 100% natural Carnauba Wax to help protect from sun, rain, wind, ice and salt spray- the elements that can attack a car's finish. It has a high foaming, concentrated car wash and wax, optimized for automotive finishes. This unique formula washes away dirt, grim-leaving a sparkling, clean shine every time you wash. It does not leave a film of wax. Use a chamois cloth to dry off your , so It does leave water spots.
    I have been using the above on car, for a long time. It removes bug/flies splats. Do not use paper on the windshield it will scratch it( like Mike Blueknight911 says), use a soft cloth to wash your windshield.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Vermont
    Quote Originally Posted by threefingers2 View Post
    Hot water & car wash soap. Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Dec 2013
    South Okanagan, BC, Canada
    Re: Downshifting
    The Spyder does a good job of downshifting when you apply the brake coming to a normal stop.
    If you want to downshift 1 or 2 gears to accelerate faster to pass someone, don't back off on the throttle.
    But if you want to use the gears to slow yourself while not using the brake, yes let off on the throttle, otherwise you're not accomplishing anything by staying on the throttle.
    Different scenarios, different process.
    Gary
    Dec 2015
    Galax VA
    I use this stuff to clean plastic windshields and my helmet visor.
    http://www.amazon.com/Prist-PGC13-Gl.../dp/B00SRQVSIW
    Friend of mine that is a pilot gave me a can back when we used to race to clean the Lexan windshields. It's made for airplane windshields.
    Mar 2015
    forrest above Reno, Nv
    Thumbs up Bugs
    HOT,HOT water on a soft clean rag. Just place it on the dried-up bug guts. Let it sit-----NO rubbing!!!
    Some parts of the bug are a hard as the plastic windshield---- thus scratching. Yes this method is solwer but your windshield is expensive. A quick wipe with Plexis or the like Before you leave make it all easier.
    Kaos
    2014 RTS , Circuit Yellow
    Dec 2013
    Use a towel or microfiber cloth soaked in preferably warm water and just lay it on top of your windshield and it will soften the bugs and they will mostly hose off. Less possibility of scratching the OEM windshield.
    Gary
    MOgang Member Yazz's Avatar
    Nov 2009
    Cypress, Texas
    Wet clothes dryer sheets.
    Joy
    Very Happy Ryder...
    '09 Phantom and a '15 F3-S
    If you don't slow down, they can't catch you..
    ​If you don't give up, they can't win.
    What a long strange journey its been.
    Jan 2016
    Default cleaner
    [QUOTE=Sam Mac;1089110]I use this stuff to clean plastic windshields and my helmet visor.
    Friend of mine that is a pilot gave me a can back when we used to race to clean the Lexan windshields. It's made for airplane windshields.[/QUOTEThanks for your tip, i just ordered 3 can's. on sale at Pilots HQ's
    A dryer sheet in a spray bottle of water. Dissolves bugs nicely.
    Sep 2014
    USA
    Mothers spray wax works fine on clean paint..
    Sep 2014
    USA
    Never heard of that trick yet..have to try sometime..
    Bryant, Arkansas
    Warm Water.
    Cruzr Joe
    Aug 2015
    central oregon
    Agree on the not using paper towels any where except wiping off the dipstick But Pledge works just fine and does not build up. I've used it for 30+ years on bikes, boats,planes and it's the go to detailer of choice for the restorations I do. It's recommended by many canvas shops for the plastic windows in boat canvas and convertible tops. JMHO
    Mar 2015
    Brockport, NY
    Default Lots of running water or hot towel
    if a hose is available, lots of running water to flush the dried on critters away, if not then another option is to soak your hotel room towel, assuming your on the road, in hot water and gently drape it over the dead bugs for a while and then they will rinse off easily with a little water from a hotel ice bucket or anything that will hold some water. The main objective is to get the bugs off so they do not scratch while you are wiping the windshield.
    Ps- the room towel thing is best done out of site of the hotel manger, or bring your own dedicated bug towel.
