Page 1 of 2 12 LastLast
Results 1 to 25 of 28
    Jul 2015
    Stockbridge, MI
    Default Tri-Axis Handlebars DO work.
    I have just completed the installation of the Tri-Axis Adjustable handlebars on my wife's 2014 ST LTD. There was only one slight modification necessary. The plastic shroud on the underside of the handlebars had two holes that didn't line up on the new bars. That was a two minute fix by drilling two new holes 1/4" away. It's nothing that will ever be seen either. My wife loves them!
    We all know how important it is to keep our "Best-Half" happy!
    Jun 2011
    Near Lexington, NC
    I'd love to have a set also. I've heard its a BIG JOB, even when done by the shop. How did it go for you? Is it something
    anyone with minimum/moderate skills might do?
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Nice farkle.
    Jul 2015
    Stockbridge, MI
    Quote Originally Posted by ulflyer View Post
    If you follow the directions it is pretty straight forward. It's still over a 6 hour installation though.
    Jan 2016
    Logan,Ohio
    Smile hocklaw
    Other short people will like this.
    Hocklawv61
    Jun 2010
    Las Vegas
    Quote Originally Posted by hocklaw61 View Post
    And so do tall people. I absolutely love my TriAxis bars and I'm tall.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Jun 2015
    Union, Missouri
    Delete
    Sep 2012
    Junction City, KS, USA
    They're the best thing I've added to my RT. For long days ryding, my shoulders really appreciate them.
    PrairieSpyder (Patti)
    Active Member cyclekid58's Avatar
    Sep 2014
    Post Falls Idaho
    Quote Originally Posted by SpyderAnn01 View Post
    I have to echo ann on that, I am tall as well and I find them adjusted a bit different than position of the standard bars, my wife is short and that's a completely different setting. We will put them on her spyder next year when we get it, so no matter who drives everybody is happy.
    Greetings from Idaho
    2014 RT-S,
    Barjaron swaybar, chome luggage rack, Ram Mount GPS, 12 volt dash outlet, spyderflap mudflap, Rivco flag mounts, drink2go and custom handlebar drink holders,Driver Backrest,Tri-Axis Handlebars, TRICLed turn signal lights. Custon Dynamic Magic Strobe Brake Modulator, Triple Dash Pouches, "Squared Away" Laser Alignment, Spyderpops Bumpskid, TricLed "Knightrider" LED
    2014 RT , White (Mine) Cognac (wifes)
    Default Congratulations. ...
    Well done .. not one of the easiest jobs to do. They are a great comfort feature and will add to the ryding time...
    ​2012 RS sm5
    Apr 2014
    full time RV'er on the road. Well we were. Now, 6 months in ThreeRivers Mi and 6 months in Apache
    Default Have to show my ignorance here.
    What is different about them? Looking at the first picture I don't notice much difference. Are they adjusted back toward the rider more?
    I am only5'8" and fit the ST fairly comfortably (I think). Please fill in the gaps.
    Jun 2014
    Plantation, Florida
    Default Tri-Axis on 2014 STS
    A big shout out to Broward Motor Sports in Fort Lauderdale, Florida.
    Their technician Tommy re-engineered my wife's 2014 STS and it now has the tri-axis adjustable handlebars.
    I am going to do this on my 2014 STS in a couple of months.
    This had never been done in their shop but they figured it out
    Jun 2014
    Plantation, Florida
    Factory says it is a 2-1/2 hour job
    Active Member Brogers57's Avatar
    Jun 2013
    Winchester, KY
    Awesome job!!
    2014 Black RTS SE6
    2012 Black RS - Sold 7/24/2014
    2011 Sonata LTD
    Very Active Member cyclelover63's Avatar
    Mar 2011
    Big Sandy, TN
    How much closer can they bring the bars to you?
    Mar 2013
    Oz
    Default Thanks
    Thank you all
    I've just had the tri-axis bars installed On my st ltd and all I can say is WOW
    i can now sit in the right place and have as much bend in my elbows as I like, it adjusts beautifully.
    still have to install the zumo 660 gps - the extra gps mount for the tri axis says it is for zumo 590 and I think they use a different mount. Clues welcome.
    Again, thanks to all who posted about these bars on an ST, very much appreciated, and yet another example of just how helpful this forum is.
    Active Member JayD's Avatar
    Oct 2015
    Cumming, Ga
    Lightbulb Tri Axis Install
    Quote Originally Posted by loisk View Post
    Thank you all
    I've just had the tri-axis installed On my st ltd and all I can say is WOW
    I mounted a standard garmin on my tri axis. Just drilled a hole
    Iin the suction cup on the window mount and mounted it in the screw hole under the rubber cap on the top of the bars. Save guite a few hundred dollars. Was able to use a bolt that wasn't needed from reinstall of thr tri axis bars. Looks good, not hacked.
    Mar 2013
    Oz
    Thanks for the GPS info. In the end we got the angle grinder to the old mount, drilled a hole, and its all good. Cheers
    Jul 2017
    Cary, NC
    Default Tri Axis on Spyder ST
    Quote Originally Posted by Bill and Cretia View Post
    Hi folks,
    i need to to adjust my bars on my 2013 ST Ltd as well. Is the 2.5 hour estimate realistic for the shop to install, or did your install take longer? Even with the ultimate seat, my shoulders kill me. I need to do something, even if it is risers ...
    Thanks to all, this is such a helpful forum, and the info is so appreciated!
    Mhbenz
    Very Active Member bscrive's Avatar
    Nov 2012
    Ottawa, Ontario
    When I installed them on my wife's old STL about 3 years ago, it took me about 4 hrs to do the install and I am very mechanically inclined. I did a write up about it back them. It should still be in here somewhere.
    Aug 2016
    South Wales UK
    Default Tri Axis Bars.
    I recently fitted a set of these bars to my 2016 RT Ltd and found them to be the cure for my aching shoulders. The only thing I found to be a problem is that because I raised the rear jacking screw nearly as high as it would go, all the switches on the bars are now out of reach of my thumbs. I will have to make some slots in the bar clamps so that I can rotate the switch assemblies back to a more comfortable position.
    Jul 2017
    Cary, NC
    Default Just do it!
    UPDATE: The dealer installed these for me. Three and a half hours labor (includes GPS) and such a big difference - no more shoulder pain and a much more enjoyable ride. Soooo worth having done!!!
    Quote Originally Posted by Mhbenz View Post
    Hi folks,
    Mhbenz
    May 2016
    Sun City West, AZ
    Quote Originally Posted by JayD View Post
    yes, I was told by my dealer it would cost $230 plus for the gps adapter. Well, I dealt with Chuck from Smith Marine USA in New Britain, PA and he sold me the tri axis bars about $200 less than my dealer quoted the gps adapter for less than $50 saving me about $175 on that. I have saved a total of over $2000.00 by dealing with Chuck ans his beother Jack. I highly recommend them
