Results 1 to 10 of 10
    Mar 2015
    Brockport, NY
    Default Adding frunk power outlet
    Looking to add a power outlet in the front trunk of my 2014 Rts. I see the part on the BRP website and it appears to be secured with a ring of sorts and plugs into the wire that should be right behind the knock out in the trunk. My question is, do I have to remove trunk to secure the outlet or will I be able reach the back side from behind and hold the ring while tightening the outlet?
    Front Cargo 12V Power Outlet Kit
    Part number: 219400366
    Product is available.
    2014 RT-S Pearl White
    Nov 2013
    Central Texas
    I had one installed when I bought my '13 RTL, and I think I have used it once. When the rolling bag is in the frunk, you cant use it at all. I use a "splitter" in the rear cargo 12V outlet which gives me two 12V outlets. Works better for me.
    May 2015
    Barryville NY
    I put in the one for the f3 under seat outlet in the frunk of my 2014 rts( 2 usb ports instead of 12v). I had to remove the frunk to do it.
    Active Member PatriotRider's Avatar
    Sep 2015
    Metairie, LA suburb New Orleans
    Cool
    I bought the socket below from Amazon for $5. Don't install the enclosed plate.
    Was able to reach in the hole already there and feel the spade connectors and wires right there. pulled them through the hole and connected the socket. Plus is center and Negative is outside edge. I then pushed it in the hole. Friction alone gripped the threads and it's "stuck" in there and working fine.
    Hope this helps.
    http://smile.amazon.com/gp/product/B...ilpage_o08_s01
    let's ride safe & be careful out there,
    Mike in Nawlins'
    2014 Black SE6 Limited "Charlotte"
    New Orleans Ride Captain
    Patriot Guard Riders
    Idaho
    Take the battery out. It's easier to reach behind the frunk through the battery hole. Find the wires and slip the locking ring over them, then pull them through the hole and connect onto the power plug. Push the plug into the hole and reach around and screw the locking ring on. Now comes the HARD part, getting the rubber boot slipped over the end of the plug to keep water off the connectors. If you have big fingers find someone with small fingers to reach in there. To call the space cramped is an understatement, but it CAN be done. I folded the rubber back over itself first before doing the above so it was a little easier to get it over the plug. Good luck!
    2014 Copper RTS
    Mar 2015
    Brockport, NY
    Default Thank ˙ou
    Much appreciated for the detailed steps, luckily i do have small hands. I think I'll wait till the garage temp is above the freezing mark.
    Linden, CA
    Default Before you do it
    Check this out from Cycle Gear $12.49 it comes with everything even the fuse holder
    Quote Originally Posted by Brentc View Post
    Nov 2015
    East Bethel MN
    I took the battery out of my wife's Rts and it wasn't to hard.thats a lot easier than the instructions said to do it .
    Nov 2017
    Gaithersburg, MD
    Default help
    Quote Originally Posted by PatriotRider View Post
    Hope this helps.
    Can you please send me the picture of this installation?
    Appreicate it.
    Happy holidays!
    Baski
    Dec 2015
    Oakley Utah
    Quote Originally Posted by oldguyinCT View Post
    I agree. That's what I do.
    2014 RTL Platinum
