Results 1 to 13 of 13
    Active Member KJWEB's Avatar
    Jun 2015
    Midland, TX
    Default Blacked-out windshield bracket
    Needing something to do this winter as the Sypdee has been parked for 8 weeks now. I used the RustOleum Black bed liner paint and now it is setting up to dry.
    www.sasspyders.com
    2016 F3T
    2015 Freedom Trailer
    Sypderpops BumpSkid Plate
    Lamonster ISP Key Cover
    Lamonster F3 Bar Clamp and Power Port
    Lamonster RIP floorboards and frame caps
    Lamonster Chevron Highway Pegs
    BajaRon Swaybar & Heim Links
    F4 Custom 21" tinted windshield
    BRP Cannonball Seat
    BRP F3 Idler Pully
    FOBO TPMS
    LidLox (dual)
    Garmin 660LM GPS
    Cat Delete Performance Pipe
    F3T Top Case
    PPA Black Widow Wheels
    Custom Frunk Wrap
    Bryant, Arkansas
    Remember to put the two rubber bumpers back on that piece before reinstalling it.
    Or your windshield will get scratched up
    Cruzr Joe
    Active Member NM Wrench's Avatar
    Apr 2014
    Albuquerque, New Mexico
    Looks good 👍
    Sent from my VS990 using Tapatalk
    14 RT-S , Stock Large brake pedal White Pearl
    Very Active Member bronzeflex42's Avatar
    Sep 2014
    Sandersville, GA
    Default looks good
    That looks good. I was thinking about chroming mine, but it don't seem to make to much of a difference in the look since it's behind the windshield IMO. I like this idea and might do the black coat instead.
    2012 Spyder RT Limited Lava Bronze (Psalm 27:1;Luke 12:4,5)
    Active Member ttrac's Avatar
    Sep 2015
    Mass.
    Looks Great, I did the same thing to my RT.
    2015 RT SE6 LIMITED, Black
    Tri Axis Handlebar,
    Ultimate Mid Rider Seat with Fuel Door
    F4 Wide Tinted Windshield, with Vent
    Tric Led Mirror Signals
    Stebel Nautilus Compact Twin Air Horn
    Bryant, Arkansas
    For a more durable finish I had mine powder coated a "Satin Black" be sure to put screws in the front holes that have threads, let the screw stick out at least a 1/2 inch so that the powder coat gets in all areas, failure to put screws in it before painting or powder coating will result in paint messing up the threads. Also ask the powder coater to pug the 6 holes in the back where the sleeve go or you will have to use emery cloth so the sleeves will go back in.
    And don't forget to replace the two rubber bumpers on the front.
    Cruzr Joe
    Jun 2015
    Midland, TX
    Default Update
    I ended up taken the bracket to get powder coated. The paint from the can scratched to easy. So, now the results from powder coated
    www.sasspyders.com
    2016 F3T
    BRP Cannonball Seat
    BRP F3 Idler Pully
    FOBO TPMS
    LidLox (dual)
    Garmin 660LM GPS
    F3T Top Case
    Custom Frunk Wrap
    Bryant, Arkansas
    Quote Originally Posted by KJWEB View Post
    Good move, you will be happier
    Cruzr Joe
    Jul 2014
    Mint Hill, NC
    That's a very sharp looking job.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Default SPRAY CAN PAINT
    ...................Been there done that, what I found that works as far as getting the paint to be about 3 times as hard, is after it dries to the touch......Put it in an oven @ 300 *F for 10 minutes and then turn oven off and just let it cool in there for 15-20 minutes. This works with any spray paint ( except the DIP type ) and makes it very hard......Of course DO NOT DO THIS WITH >>>>PLASTIC PARTS........Mike
    Jul 2014
    Central Texas
    Quote Originally Posted by [COLOR=#b22222
    Of course DO NOT DO THIS WITH >>>>PLASTIC PARTS........Mike [/COLOR]
    Tried once in the 80s to unwarp a record (big black plastic disk for all the kids out there) by putting it in the oven. Would have worked had I remembered that it was in the oven.
    Looking good.
    Very Active Member Purple Guy's Avatar
    May 2013
    Edmonton Alberta, Canada
    Powder Coated mine and it is the best $50 Farkle on my Spyder!
    2014 RT-Ltd , Cognac
