Remember to put the two rubber bumpers back on that piece before reinstalling it.
Or your windshield will get scratched up
Cruzr Joe
Looks good 👍
Sent from my VS990 using Tapatalk
14 RT-S , Stock Large brake pedal White Pearl
looks good
That looks good. I was thinking about chroming mine, but it don't seem to make to much of a difference in the look since it's behind the windshield IMO. I like this idea and might do the black coat instead.
2012 Spyder RT Limited Lava Bronze (Psalm 27:1;Luke 12:4,5)
Looks Great, I did the same thing to my RT.
For a more durable finish I had mine powder coated a "Satin Black" be sure to put screws in the front holes that have threads, let the screw stick out at least a 1/2 inch so that the powder coat gets in all areas, failure to put screws in it before painting or powder coating will result in paint messing up the threads. Also ask the powder coater to pug the 6 holes in the back where the sleeve go or you will have to use emery cloth so the sleeves will go back in.
And don't forget to replace the two rubber bumpers on the front.
Cruzr Joe
Update
I ended up taken the bracket to get powder coated. The paint from the can scratched to easy. So, now the results from powder coated
That's a very sharp looking job.
SPRAY CAN PAINT
Originally Posted by [COLOR=#b22222
Of course DO NOT DO THIS WITH >>>>PLASTIC PARTS........Mike [/COLOR]
Tried once in the 80s to unwarp a record (big black plastic disk for all the kids out there) by putting it in the oven. Would have worked had I remembered that it was in the oven.
Powder Coated mine and it is the best $50 Farkle on my Spyder!
