Givi rack used to hang wheelchair, much easier on your shoulders and arms, independen
I am about to buy a F3 with Givi panniers and I use the left hand side for hanging the wheelchair. I did this on the RS spyder and you can see how easy it is to take the WC off and on. This is the clip that I made up.
At the back it is held on by a U clip that goes into your push rails and I just used a clamp using bolts and nuts and the Givi frame and the front of the chair sits onto the rear footpegs then I use a thick rubber strap to go over the chair, where you sit on when the chair is open. I do use a folding chair. If you have any question email me on 97landy@gmail.com and my name is Greg. I have done 55000k and it has only come off twice and that is with a pillion. The wheels hit the ground and came off. I have since put a better shock obsorber on the back and have had no problems. Much easier on your shoulders and the chair faces towards you and not reversed.
wc rack
Greg I also have an f3s and will be mounting my wheelchair on the left side I use a tilite folding
chair i had a bracket on my 2013 st limited but it will not transfer to my f3s I was not abel to see any photos of your mount if you can post them that would be great thanks in advance for your info my name is Ric and i have a t10 spinal cord injury.
ric
