Results 1 to 11 of 11
    May 2015
    Gastonia North Carolina
    Default F3T Audio retro fit
    Does anyone know if the audio system for the F3T can be retro fitted to the F3S I couldn't get an answer from my dealer
    Aug 2007
    Springfield, MO
    Shark Audio 1400 watt system for under $200.00
    Default SHARK AUDIO
    ...with Lamont , I've had two and they were great.....after I swapped out the speakers for JBL - GTO 328's, which are 2 OHM's the system really rocked.......................Mike
    Very Active Member bscrive's Avatar
    Nov 2012
    Ottawa, Ontario
    Quote Originally Posted by DavieT View Post
    I am not sure why you would want that overly expensive system anyways. The Shark, like Lamont says, is a lot cheaper and better. Easier to hook up as well. I have one on my 1800 Valkyrie, and it rocks. My wife just uses an iPod hooked into her Sena.
    Jun 2015
    Sparks, NV
    Default Yeppers, agree with Shark
    I've got a Shark on my F3S and it works great....
    Jul 2010
    kansas ottawa
    heres mine on my f3s and it works fine ive had this shark on 3 other bikes befor I put it on here.
    May 2013
    Apex, N.C.
    I had the shark system on my Suzuki boulevard M109R. The only complaint that I had was with the Chrome finish. After about a year, the chromed plastic tarnished and could not be corrected. If you go with black or some other finish, it should be fine. I also linked mine into the speakers that were mounted in with the corbin bags and it worked fine up to about 75+ mph.
    Aug 2007
    Springfield, MO
    To answer your question directly. Yes it could be done but the cost would be crazy. Just go through the parts and add them up. You would have to change out the whole top console as it's part of why you can get such great sound.
    Invalid Emails
    Nov 2008
    Joliet IL
    Default Two things...
    First, I bought the F3 Power plate and the quality and install video made it a snap to install. But I would have paid $5 more if it had the bit that fit the allen head of the bolt. It fell between the standard sizes that were in my sets.
    Second, I bought the Shark audio 1400 watt stereo for install on my F3-S. Is there any advantage to wiring it directly to the batter compared to the accessory circuit ? I have all of the accessories that I need, this is the last one. Does it make a difference besides being able to play the music when the bike is off ?
    Looking forward to buying more of your quality add ons to the Spyder F3
    Mar 2015
    NEW JERSEY
    Default NEED I SAY MORE.
    Feb 2013
    Arlington VA
    Default Radio System
    What type of system do you have and where did you get it installed?
    Quote Originally Posted by WIDOWSSON View Post
