Page 1 of 2 12 LastLast
Results 1 to 25 of 49
    Jun 2013
    queens ny
    Default well i got my CPAP machine
    so tonight will be the first try with it, i hope it helps me sleep. the name of the machine is RESMED and it is fully automatic. with my test results the doctor told them what air pressure to set it at, and they gave me a mask that covers my nose and mouth., the air pressure that it is set at is one that during the day i can blow leafs with it. the setting is 5 - 15
    NO BIKE AT THIS TIME
    Jun 2014
    People's Republic of NY
    Good luck, I hope it helps.
    sleep well
    committee for postings
    Very Active Member 2ndChildhood's Avatar
    Sep 2012
    Flushing , Michigan
    I've been using a CPAP almost 10 years. I now have a brand-new one exactly like yours and absolutely love it. I get a report every day on how I did. What's really nice about it is adjust itself if I start having problems it increases or decrease the pressure. Far superior than the old machine. Good luck with yours and just take your time to get used to it.
    ToM
    Life is Great
    Be Safe
    Life is Great
    ToM
    Jun 2013
    queens ny
    my two dogs are not happy with me with the mask on, my one is growling at it
    Jun 2014
    Sep 2012
    Junction City, KS, USA
    Glad you're taking care of yourself, John.
    PrairieSpyder (Patti)
    Very Active Member Ron2andia's Avatar
    Jun 2012
    Phila
    May God look out for you. Hope all goes well!
    Live, Love, and Ride! God Bless!
    Active Member Thump's Avatar
    Jul 2015
    Colorado Springs
    Good for you!
    So one nice benefit is that when the sun is shining in your window at 0600 you can put a pillow over your face and still breathe just fine!
    Best of luck
    Thump
    Oct 2013
    rome new york
    Keep us posted John how it works.
    I should probably get tested. My wife says i stop breathing sometimes while sleeping.
    Told her i wouldn't if she would quit putting a pillow over my face
    Very Active Member Magdave's Avatar
    Jun 2013
    NE South Carolina
    I have this one for the last 3 yrs
    I have just the nose pillows
    It really sucks the distilled water up in the winter it barely uses any in the summer humidity. I used to quit breathing a lot.
    2013 Mag Silver SE5 RT BahaRon Sway bar & Sway bar links, Grip Puppies, Kuryakyn Helmet locks , Ultimate Seat w/Utopia Backrest, Dash power outlet, Spyderpops BumpSkid, Swagman Cup holders, Full size Brake Pedal, Seal DLX Floorboards, Freeway Blaster horns, Sylvania Super Bright fender LEDs, Scotchlite 680 Rear & Fender Reflectors, BRP Fog Light Kit, LED Mirror turn signal strips, 2014 RT grille mod. Outlaw Laser Alignment
    Jun 2013
    queens ny
    this is the mask i got
    Nov 2013
    Oro Valley Arizona
    Quote Originally Posted by Magdave View Post
    That's what I have. I like them better than the mask.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Active Member TommyBwell's Avatar
    Jun 2014
    Atlanta, GA
    You may have trouble sealing that mask with your facial hair. I use the nasal pillow like the other boys and it works great.
    It it will take a little while to get used to but then you will get to the point that you don't even think about it.
    May 2015
    Oregon, USA
    Welcome to nights of better sleep, and waking up rested!
    It's been amazing difference for me. I use the nose pillows like the pictures above as well, which work well for me.
    -Fratz
    Jul 2010
    Las Vegas, NV
    Default Works great!
    Funny, I dozed off today on the sofa, and woke up several times, gasping for air. The CPAP allows such good sleep, it is a waste of time to not use it. Takes a while to get used to it, but well worth it! Good luck, and sweet dreams!
    Joe Meyer
    Jun 2013
    queens ny
    almost 3 can't sleep with the machine on, feel like i am claustrophobic
    Feb 2012
    Spring City,Utah
    I have the same machine as Magdave but I use a nose mask. I see you are having trouble sleeping and feeling claustrophobic. You may need to go to some other kind of mask such as nasal pillows. One of the things that helped me is thinking about the helmet and masks I wear riding. or the safety gear I wore when working in the steel mill. Don't give up or get discouraged. This has the potential to give you your life back and to allow you to have a much higher quality of life. I have been on my machine now for 15 years and wouldn't dream of sleeping without it. You can get over this.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Dec 2015
    Illawarra
    When ya tired enough, you'll sleep
    Jun 2013
    queens ny
    worst nights sleep i have had in years. i managed to sleep for 1 and a half hrs. and as of right now i hate it.
    Very Active Member daveinva's Avatar
    Mar 2011
    Washington, D.C.
    Ugh, I still remember those first days and weeks with CPAP, how I hated it. Unfortunately, I never quite reached that place people rave about-- "Best night's sleep in years!" It just kept me going long enough to lose weight and resolve my apnea.
    cuznjohn, a few tips:
    -- I had a full mask like that, it rubbed the bridge of my nose raw. Solved the trick with cutting a small strip of moleskin and putting that on the bridge of my nose every night. http://www.walgreens.com/q/moleskin#!
    -- Humidity helps a lot, so if your machine has a water tank, keep it full and clean. (If it *doesn't* have a water tank, consider getting a model that does).
    -- This little pole kept the hose off my head, making it easier to sleep on my side. http://www.cpap.com/productpage/flex...hose-lift.html
    -- I never could do the nasal pillows, never found any that were comfortable. As bad as the full face mask was, I got used to it in time, never could say the same for the pillows.
    That said, this new mask has gotten a lot of press recently, it sounds like it's quite revolutionary-- might be worth looking into.
    Stick with it, and good luck!
    https://www.sleepapnea.com/products/.../overview.html
    Silver 2010 RS SE5: Triple Play, Taillight, Brightsides, Fender Tips, Easy Risers; Evo Sway Bar; Airhawk R & Beadrider; latch springs; Grab-On grips; Crampbuster; 24" Madstad smoke windshield & deflectors; N-R round bag & soft saddlebags; BRP handlebar bag; Throttlemeister; Spyderpops Missing Air Dam & Air Mgmt System; Rivco driver & passenger boards & pegs; ISCI parking brake extension; Ultimate Midrider Seat w/both backrests, Fox Racing Shocks, Yoshi R-77 exhaust and a whole lotta love!
    Please don't start hating I just yet...
    Give yourself some time to get used to it.
    Very Active Member mowin's Avatar
    Jun 2011
    upstate ny
    John, when I first got mine, that mask took many flights acrossed the room. It took me weeks. I was so discouraged. I tried the nasal pillows, but my pressure was so high, it wouldn't seal. The hardest part, was trying to keep my mouth shut. I'd just get to sleep, and the noise it would make when I opened my mouth would scare the crap out of me and of course wake me up.. I ended up trying it for a hr or two each night. As soon as I'd wake up, I'd remove it, and continue the night without it. Eventually, I could make it half way through the night, and fall back asleep with the mask on.
    Don't give up.
    Oct 2013
    rome new york
    FORGE ON JOHN
    Idaho
    Quote Originally Posted by cuznjohn View Post
    Be comforted by knowing you are not alone or unusual. If you haven't yet, I strongly urge you to go to www.cpaptalk.com and join the forum there. Others who have contended with those exact issues will offer suggestions and encouragement on how to make the adjustment. Also, you will learn how to download and view all the data from your machine and see just what's happening. One of the big shocks for new users is learning how little support often comes from the Doctor or DME who got you into this therapy. You will learn what to do to take control for yourself of your therapy. The success rate for those who are proactive in managing their treatment for themselves is quite high.
    2014 Copper RTS
    Nov 2013
    Central Texas
    John, I agree with Magdave. I have had my CPAP for about a year, and I use the nose pillows also. I tried the full mask and found it to be too claustrophobic, as well as not sealing well due to my beard. I wouldn't have shaved it anyway. It took me a while to get used to using it, and the only drawback that I have found is that even though I am breathing humidified air, I wake up occasionally during the night as well as every morning with dry mouth. I keep an insulated tumbler of ice water on my nightstand, and that has helped a lot. Hang in there pal, it may take a while. You know us older guys hate change worse than cats do.
