I forgot where the post was about what a PITA it is to get at the fill valve on the RT's so this is a new post about the same problem. (If the moderators wish to combine this with other posts about this issue have at it)
As you know getting at the tire fill valve can be a PITA on the RT's, not sure about other models. Anyway this is what I use. I picked up a filler at O'Rielly's auto parts for about $7.00 and a couple air fittings and a pressure gauge that I had from my racing days and I have this. I did have to put a bend in the filler. The tire filler will now reach in from the back side of the wheel or from behind the belt pulley. I air up the tire with my shop air then connect the gauge that has a bleeder valve on it to the filler to adjust the pressure.
Curiously; I've never had much trouble getting to the rear valve stem...
It has JUST enough flexibility to allow you to get the gauge and the air chuck on it...
What's tough: Finding it on that damned rim in a poorly-lit garage!
For what ever it's worth getting at it on my 2014RT was a PITA. I don't understand why they didn't put it on the brake side of the rim. Oh Well it is what it is.
I just checked the air In my tires today, I have never had a problem getting to the rear valve stem on my,A group of us are going on a dinner ride tomorrow, supposed to be near 70* In the Buckeye state..
2013 Viper Red RT S-SE5 All 48 states on a Gold Wing now I'm working on getting all on a
Maybe I have an odd ball, anyway on my machine the tire fill is right behind the pulley for the belt and it's at an angle that makes it difficult to get at with common tire gauges or fillers. Your results may differ. My issue is now solved and I only posted to help others that may have the same problem. Just trying to be helpful.
The last two rear tires that were installed--they did not position the filler valve so it was in the open. A genuine PITA.
Will make sure I have a discussion on the next rear tire.
Yes, you definitely need to be sure that they have the pulley positioned properly or you'll be wishing for your rear tire to wear out faster than a Kenda.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
so for $ 10 you can go to your local Harley and buy a 6 to 8 inch extention so you can get the end out where you can fill it easier and check pressure easier. Works like a charm.
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
Or if you ever owned a Harley Touring class, use the gauge on the rear shock air hand pump. Very flexible end and a screw down connection with very little leakage.
AJ
2014 RT-S Akrapovic Exhaust & Cat Bypass
Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
Comfort Seat w Adjustable Backrest
Decals by Purple Harley / Magic Strobe
Kuryakyn Black Widow Pegs Rivco Highway Brackets
Rivco Trunk Mounted Double Flag Holder
FOBO / Spyder Cuff / XM Radio w MC Antenna
You probably don't have any odd ball; they are a PITA to deal with. Your solution is fantastic and another way to deal with the foibles of our toys
All the great movements in the world began with a cup of coffee!
2018 F3-T
My mods: Can am Trailer hitch, USB and 12 volt power outlets, Gustason windshield, Bead rider seat cushion, battery harness for electric gear and battery tender, Time out trailer.
Yes, I have a 2015 RT Limited and have no problem with servicing the rear tire, but do have a nice assortment of fittings and gauges after having a Harley Ultra Classic. When I bought it, it had a beautiful set of chrome spoked wheels, that required me, to put air in them, to remove the left saddlebag, lay on the ground and wrap my arm around the wheel to hold the fitting on the valve stem, and add air with my right hand. The solution was to by another set of wheels. I love my Spyder.
David
How old would you be if you didn't know how old you were?
Try the EZ Air Tire Gauge from Amazon, I just bought one for $20.00 and it works great. Put it on the tire easily and check the pressure and put air in with the same unit. Check it out!!
And you folks know my tires well, since you had to contend with them during the alignment.
That is what I did - eazypeazy.
2015 RT Ltd , Canamspyderaccessories Brake pedal ext. Red
I have a difficult time with my 14 RT as well however I picked up an extension hose several years ago for my BMW. The air valves on that bike were wedged in a very small opening and it was darn near impossible to get a reading. I had to order a few parts for the bike and came across the extension, and it works very well on the RT. It was and still is only 4.99 so I didn't think that was very bad especially since I had other items on the order to spread the shipping cost over.
