I see you used my Circuit Yellow image but you have a white background. It should be transparent (no background showing).
This mean the way you loaded it or something converted it from a GIF to jpg or something like that.
You should be able to get it loaded with no background showing like this:
Bob
2011 RT-S SM5 - Black
Apologies if this has been covered previously but I can't find anything. If for security reasons the caps will only work with the phone they are first paired with, until they are unpaired from that phone. What happens if the phone is lost or breaks? Do I have to buy new caps?
I am looking into getting a 4 set of FOBOs for my Spyder. 3 for tires and 1 for rear suspension. Question: What should the Max, Min and Recommended PSI be for the Rear Suspension? I have a 2011 RT Limited and I am a BIG boy (265lbs)
Paul "Wingman" Metheney
2020 Can-Am Spyder RT Limited
The Spec for the air shock is (as I recall) 30-90 PSI.
I have the compressor on my RTS and notice in general it run between 40 and 70 PSI.
I have set my min and max for the air shock to Min 32 and Max 80.
Bob
