Results 1 to 17 of 17
    Aug 2015
    Georgia
    Default driver backrest upgrade
    has anyone ordered and received the $79.00 driver backrest upgrade that will allow some back lean motion? ordered one from the local dealer $70, but it won't be in till late Dec. hoping it provides some relief.
    Active Member cyclekid58's Avatar
    Sep 2014
    Post Falls Idaho
    Default Drivers Backrest
    Quote Originally Posted by rtga View Post
    Not yet but we will be axiously watching for your next post with some install pics and how it works for you, I plan on getting one myself in the near future.
    Greetings from Idaho
    2014 RT-S,
    Barjaron swaybar, chome luggage rack, Ram Mount GPS, 12 volt dash outlet, spyderflap mudflap, Rivco flag mounts, drink2go and custom handlebar drink holders,Driver Backrest,Tri-Axis Handlebars, TRICLed turn signal lights. Custon Dynamic Magic Strobe Brake Modulator, Triple Dash Pouches, "Squared Away" Laser Alignment, Spyderpops Bumpskid, TricLed "Knightrider" LED
    2014 RT , White (Mine) Cognac (wifes)
    May 2013
    Apex, N.C.
    Quote Originally Posted by cyclekid58 View Post
    I will also be awaiting a review. I think it should be very nice.
    Active Member kywinger's Avatar
    Sep 2015
    Carrollton, KY
    Tried the BRP back rest and didn't like how it pushed me forward.
    Adding some adjustment might make the back rest usable.
    Mar 2014
    MI
    Question Requirements in BRP catalog for this item
    I also am anxiously awaiting info on this item!
    I am confused to whether it will work for mine
    2014 RT-S with heated comfort seat and driver-backrest. I think it will (but can't tell from the catalog numbers) because I bought my RT-S and options new and all at once.
    It'll fit...
    For a comfort seat; the part # is: 219400683
    The regular seats get part #:219400682
    Aug 2015
    Georgia
    [QUOTE=kywinger;1069381]Tried the BRP back rest and didn't like how it pushed me forward.
    I adjusted the bracket under the seat to tilt back about 3/4 of an inch. it made a little bit of a difference. I am hoping the new backrest bracket will give me a little more lean?
    May 2014
    Cornish, Maine
    Default backrest upgrade.
    One thing I did with my Show Chrome Utopia(?) back rest was remove the stock foam and replaced with a cutout from an old egg crate foem mattress pad and folded it over itself to double up/smooth the egg shape. it is softer and gave me more room and did away with that "push forward" feeling.
    May 2015
    Urbana, Ohio
    Default BRP adjustable driver backrest upgrade kit
    I ordered my back in mid Oct and should be in Monday 12/28/15.
    Mar 2015
    Brockport, NY
    Default Survey says......
    Quote Originally Posted by John Moody View Post
    John, let us know when you get it installed. I'm also thinking of getting one and would appreciate your feedback.
    2014 RT-S Pearl White
    May 2015
    Urbana, Ohio
    Quote Originally Posted by Brentc View Post
    install my adjustable back rest on 1/12/16, unable to test it out until two week ago. I love the adjustable backrest, still need to fine turn the best alinement for me but lot better than stock with no adjustment.
    Sep 2014
    Post Falls Idaho
    I installed my upgrade kit, best I could do was try various settings in the garage as we haven't gotten out yet, winter hasn't made up it's mind to go away. I did find for me, setting the adjustment screw all the way down for max recline makes a world of difference for me, it's real easy to adjust with a T-handle allen instead of standard as it will need a different setting when the wife drives. This appears that it will give me the comfort I need as without the kit it pushed me too far forward.
    2014 RT-S,
    Active Member LJspydee's Avatar
    Nov 2012
    Casa GrandeAZ/formally WaterlooIA
    Default Adjustable driver backrest
    I installed the adjustable backrest support and think it's a great improvement. It was a little tricky getting the pivot pin in with the spring, but doable. We have noticed that my wife has to hold the backrest down when getting on and off because of the spring, which wasn't on the original backrest. But I do like being able the adjust the angle.
    2013 Silverado 2500HD Duramax
    2017 Honda Pilot
    2018 Maverick Trail 1000 DPS
    2015 RTS SE6 Intense Red Pearl
    2014 35' Keystone Fuzion Impact Toyhauler
    Ultimate Seats passenger backrest, Adjustable wind deflectors, Minitrailer USA trailer, Can Am driver backrest, Corbin passenger armrests, after market hitch, DIY bump skid, LED turn indicaters, cup holders, frunk decal stripes, DIY GPS mount, DIY Gopro dash mount, aux 12v & USB outlets, DIY belt rock shield, BajaRon swaybar, frunk 12v outlet
    May 2013
    Apex, N.C.
    Seems like this will be my next farkle. Thanks for the reviews. I have gotten pretty used to my stock one for now, but if it will improve things, $70-80 isn't bad. Probably an easy sell if I find I like the stock setting better.
    Active Member Voyager_PWS's Avatar
    Apr 2015
    Columbus, OH
    I got one of the adjustable backrest mounts for the wife's spyder but I am not having any luck getting the zippers to unzip. Anyone have any tips/tricks/ways to get them to unzip???
    Patrick Sharon
    2020 F3 Limited Black/Chrome
    2021 F3 Limited Liquid Titanium/Dark
    Columbus, OH
    Danbury Connecticut
    IBA #47122
    2020 RT Limited Asphalt Grey
    Apr 2015
    Columbus, OH
    THANK YOU THANK YOU THANK YOU!!!!!!
    Patrick Sharon
    Columbus, OH
