Results 1 to 21 of 21
Thread: TOP SECRET
    Very Active Member SPYD3R's Avatar
    Apr 2011
    GREENVILLE, SC
    Default TOP SECRET
    OK, I GUESS BRP IS KEEPING THIS TOP SECRET....
    CHANGING OUT THE HEAD LIGHT BULBS ON THE
    F3....
    NOT THE AUXILIARY LIGHTS, BUT THOSE BIG BAD HEAD LIGHTS.....
    I CHECK THE MANUAL -
    ZILTCH....
    I CHECK THE WEB -
    ZIP....
    WHAT GIVES WITH THIS....? HAS ANYONE CHANGED THEIRS, AND WHAT IS NEEDED TO DO SO....?
    THX IN ADVANCE FOR YOUR HELP....
    DAN P
    SPYD3R F3-S
    Very Active Member Darren111's Avatar
    May 2015
    Leeds, England
    Default You Tube
    You Tube has your answer I hope
    2015 F3-S in Magnesium with Can Am red frame
    Blue Ridge Windscreen
    Heated Grips
    Name of my F3-S - Sandra
    Xmas present to me and from myself on 6/11/2015 - 02/09/2018
    2019 F3-S Special Series in Liquid Titanium with Orange frame
    Heated Grips
    Signature Light with switch to turn it off and on.
    Name of my F3-S - Pamela
    2019 F3-S Special Series , Liquid Titanium with orange frame
    Apr 2011
    GREENVILLE, SC
    Default looked
    Quote Originally Posted by Darren111 View Post
    searched u-tube..... nothing there... only the aux lites....
    thx
    Apr 2010
    Thorn Hill, TN
    Looking at the manual it looks like an all day sucker. You need to remove the following; L/R service panels, R/L side panels, Remove screws L/R securing top rails, Remove retaking screws inside gauge support both sides, Loosen console nose lower retaining screw, Unclip upper portion of nose, then pivot forward,, Remove key switch cover, Remove central bezel, Remove console panel. This will get you to where you have access to the bulb. There may be a step or two that I missed, but if you are going this deep it should be minor. Good luck.
    Jun 2010
    Las Vegas
    BRP sure knows how to make changing a light bulb difficult. I think I would have been disappointed if changing the headlights on the F3 was easy.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Oct 2013
    rome new york
    Spend that kinda money and need to hire an engineer to change a bulb.
    YOU ROCK BRP
    Apr 2012
    Northglenn Colorado
    actually it is pretty easy to do. Only takes about hour.
    Apr 2011
    GREENVILLE, SC
    Default HOLY
    Quote Originally Posted by fencepost View Post
    HOLY ! ! !
    ARE YOU KIDDING ME.....?????????
    I SUPPOSE I'LL NEED TO REMOVE THE REAR WHEEL ALSO..... WOW, THIS JUST AIN'T RIGHT... BRP, PLEASE CALL ME, AND I'LL DESIGN YOUR PRODUCTS SO THEY ARE "SERVICE FRIENDLY".... OR CALL THE BOEING AIRCRAFT COMPANY AND ASK THEM IF YOU CAN USE THEIR CATIA SYSTEM...... GAWD, THIS IS INSANE..... THX ANYWAYS.....DAN P
    SPYD3R F3-S
    Nov 2015
    Florida is home, working in Oregon
    Don't buy a 2013 or newer Ford Fusion!! Gotta pull the whole front nose off to change a headlight...
    Linden, CA
    Default This is what you get when.....
    I am sure that the CanAm Spyder, all models,
    are designed by NON mechanical minded folks
    who never have or will ever have to fix anything
    or change a light bulb, I am sure they are all designed by
    committee, picture a bunch of people who don't ride or
    never have sitting around a big oval table trying to design
    the Spyders and doing a fine job of making every damn thing on them
    hard to get to or repair....
    Quote Originally Posted by SPYD3R View Post
    F3....
    ZILTCH....
    I CHECK THE WEB -
    ZIP....
    DAN P
    SPYD3R F3-S
    Linden, CA
    Same with the Cheve. & Buick but I found
    an easy way to do it without removing any
    body parts....
    QUOTE=Tweakers;1066019]Don't buy a 2013 or newer Ford Fusion!! Gotta pull the whole front nose off to change a headlight...[/QUOTE]
    Jul 2011
    Mitchell, Ontario, Canada
    F3....
    ZILTCH....
    I CHECK THE WEB -
    ZIP....
    DAN P
    SPYD3R F3-S
    Those dirty scoundrels at BRP hiding the headlight changeout procedure in the owner's manual. They know darn well nobody reads that.
    To be even more devious they put it in the section call "How to replace fuses and lights." Who would ever look there.
    2018 F3 LIMITED
    Apr 2011
    GREENVILLE, SC
    Default CORRECTED
    OMG, I STAND CORRECTED.....
    THX FOR POINTING ME IN THE RIGHT DIRECTION BOVINE...
    UNLIKE THOSE THAT NEVER MAKE MISTAKES, I ON OCCASION DO...
    MY HEART FELT APPOLOGIES TO THE
    BRP STAFF....
    DAN P
    SPYD3R F3-S
    Very Active Member CanAmChris's Avatar
    Feb 2011
    Near Philly, PA - USA
    Not true Billy, everyone reads the manual. They turn right to the page with the oil change schedule, read it, close the book, put it down and promptly forget where they left it.
    It looks as if the fun starts at page 118 in the 2015 manual...
    Very Active Member MRH's Avatar
    Apr 2012
    Los Angeles and Santa Ynez, CA
    How many Spyderlovers does it take to change a lightbulb?
    (rhetorical question)
    2020 RT Limited in the ultra cool Deep Marsala Dark edition.
    Baja Ron Anti-Sway Bar, LED reflectors, Lamonster USB Charger (and phone mount), Can-Am Low Windshield, X-Creen Tour Variable Windscreen Spoiler Blade, Power Commander, Dilithium powered Flux Capacitor (not yet fully functional).
    Maintained by Lou at Pirate Powersports.
    Oct 2015
    Alabama
    With the time it took you to add all of the silly emoticons, bold letters, fonts, colors, you could have changed your headlights and mine.
    Good grief....
    HOLY ! ! !
    SPYD3R F3-S
    Apr 2015
    Green Bay, WI
    Default Headlight change on 2012 GMC Acadia Denali
    Quote Originally Posted by Tweakers View Post
    My headlight went out & I was about to research the replacement procedure---about the same time I got a GM recall letter stating if a problem occurs with headlights they will change it out for free---something about light heatshield not being effective.
    I read the procedure--highlights include removing the front fender & front bumper assy. The tech at the GMC stated the invoice would have exceeded $2000--they replaced both headlights & heat shields.
    Really sounds crazy---used to take 1/2 dozen screw removals.
    I should have asked "how much wil it cost "without the girl"
    Quote Originally Posted by MRH View Post
    However; an answer does exist...
    Once the original question has been posted; you will get 30 responses.
    Since the OP never lists their bike model in their signature...
    1 response will be to ask which model
    2 will remind the OP that by listing this info; they save lots of time
    1 will be to ask how to put this info into their signature
    2 will be for the incorrect model of Spyder...
    3 will have War Stories about what it took for their Dealer to change it.
    1 will complain about trying to get it changed at a Dealership where they didn't buy the bike
    4 will complain about Dealership Labor costs
    4 will complain about how the Dealerships train their personnel
    2 will tell you how easy it is to do by yourself
    3 will say that they never had to change a bulb in their Harley/Honda/Kawasaki/Indian/Suzuki/Yamaha/Victory
    2 will mention that all of the bulbs come from Thailand
    3 will tell humorous stories about reminding their Harley-riding friends of that fact....
    1 will actually give you the proper instructions
    and...
    1 will post a video...
    Jun 2014
    Southern New Jersey
    How many Can Am riders does it take to change a light bulb???
    Quote Originally Posted by Commander View Post
    Just one; but the online chatter about it will, persist for weeks!
