Inaccuate Thermometer Reading
Anyone have an inaccurate thermometer reading on their dash? I've been riding to work the last few days and my dash digital thermometer has been reading 40-50 when it was in the 30's. My Spyder is grage kept so I wonder if it is reading the garage temp and just takes awhile to adjust to outside. No big deal, just wondering.
Temps....
The placement of the sending unit is to blame. It is more for the temp of the air flow to the throttle bodies than what you are feeling. It picks up a lot of road heat and you will find that in the summer months it will read well above the temp your feeling. Asphalt tends to be very hot in the summer and still warmer in the winter. You can get a little stick on temp guage for your dash if you want the real temp and check the wind chill chart for your travel temp...
2012 RS sm5
Thanks
Actually; that reading was never meant to reflect the actual temperatures in which you ride.
The sensor is up under the bodywork, and takes it reading from there in order to give an accurate number to the computers. That way, the fuel mixtures can be properly set.
Remember; it's the air temperature from where the air is being drawn, that matters!
Thanks...You learn something new everyday. I was just riding and freezing my rump this morning and saw it said 45 degrees. I said to myself, "self, there is no friggin' way it is 45 degrees out here." But I was listening to tunes and the roads were wide open due to no one working in the DC area and I was happy.
Happy Thanksgiving
Thanks
Nah, Its not that big of deal. I am brand new to this Spyder thing so just trying to learn about my equipment.
Happy Thanksgiving
My observations have been that it does reflect within a degree or two the actual air temperature, but it is very slow to respond to changes, like on the order of 10 to 15 minutes. In the sun it will show well above ambient due to the tupperware heating up. I had times when I got a check engine error after being parked for awhile because the temp was showing 120+ in sunny 105°F weather.
2014 Copper RTS
this posting has been vetted, scrubbed and endorsed by the committee for postings
Aw come on folks, we only paid $25-30K for these things, how can you expect to have an accurate temp gauge, or clock, for that matter.
Two Wheelers from 1963-2011
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
2022 RT current ride(silver)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
Is anyone there
Originally Posted by Cruzr Joe
No one ever works in the DC area
Anonymous
ever truthful?
Doug Barnes
James 4:17
all on two wheels. More on four or more. Guess I may need to start multi-coloring for three wheels.
Next you'll be asking for an accurate fuel guage.
and if BRP gives you that, you'll expect an accurate clock, and a useful speedometer.
You see how this would be a corporate slippery slope. I think you should trust your skin sensations.
Flatlander, Navy Veteran, Widower
Loved my 2014 RTS SE6 Pearl white
but have a new love now,
my 2017 RTS SE6 Champagne metallic (Champ)
I thought mine was pretty close until yesterday when the high was 52 and it was reading in the mid/upper 60's.
Noted, nothing has a correct reading on my RS-S. Speedo 3 mph low, temp out side temp high, clock too fast, and who knows how much fuel on board?
If I can't fix it, I will fix it so no one can fix it. Sypder Loco!
Truthfully: BRP should never have put that reading in the display...
If they wanted an accurate thermometer for our use; it would have required another sensor, that was mounted in a completely different place...
It sounds like it's an in-process metric that only the systems need. If there's a problem (process result) that's what we'd want to know.
Mine is fairly accurate, but as noted, is slow to react. However, the clock is horribly inaccurate and needs to reset every month or so.
2020 RTL SE6
Since it's Thanksgiving...
I am thankful for the VERY accurate fuel gauge, that BRP equipped my 2014 RT-L with...
It is by far; the most accurate fuel gauge that I've had in ANY vehicle that I've ever owned!
When the low fuel light comes on; I know that it'll take just over 5.5 gallons of fuel!
Is that the in dash gauge, or the cluster digital gauge? If you remove the in dash gauge is the digital one just as accurate? I would think it would be, but just wondering.
2014 Copper RTS
