I knocked off the tag light once when it was in our trailer. Luckily it was easy to crazy glue it back together.
JLohPhotos
Have heard of few going missing before, who how & when I dont know. Glad you spotted instead a cop letting you know with a ticket
2013 STL SE5 BLACK CURRANT
SpyderPop's: LED bumpskid
minispyder dash toy
Lid lox
KradelLock
Pakitrack
FLO (Frunk Lid Organizer)
BRP fog lights, trailer hitch
SENA 20S EVO
The light cover is available separately from Custom Dynamics for $20. Actually thiers is an improved version that is also a tail light instead of a reflector. Its only held on with one screw. I have lost 3 of them until i glued the last one on.
I've had two RS's, both had that light fall off within the first 2000 miles! Suggest you glue it on if replaced.
HOT GLUE
B4 U GLUE IT ON, GIVE CONSIDERATION TO THE FACT THAT 1 DAY U MAY NEED 2 REPLACE THE BLUB....
what a mess that will be....
what i did was, take the little screw out, then with my HOT GLUE gun, i added a tab of hot glue to the screw and screwed it back in b4 it solidified.... kind'a like LOCTITE without the permanency... now if you ever need to replace the bulb, it will be easy to unscrew that little bugger without a big mess or braking the housing...
jmho
Dan P
SPYD3R F3-S
Happened to me
It happened to me, but the taillight cover had a little help coming off as my gal parked the ST-L in the garage, but the taillight was too close when the garage door came down and cracked it. I took the opportunity to replace it with the TricLED lighted taillight cover as it was better and cheaper than the OEM. You are not alone with this problem, my friend...
Thanks for the ideas! I am going to take a look at the new one to see what I will do to try to keep it from coming apart again. I like the light instead of a reflector idea!
Y'all ride safe!!
I lost mine also...wasn't gonna pay 50.00 for the whole brake light,jus to take the cover off! So I jus went AM (after market)
Sent from my SM-N910T using Tapatalk
OK, I replaced the tag light cover, but I put "GOOP" glue on the vertical edges and on the inside of where the screw anchors to the fixture. I hope this lasts longer than the 1st one.
