Compairison between Belt vibration --Smooth Spyder versus Baker-Built
Has sanyone compared the 3000--4400 RPM vibration decrease between the Smooth Spyder & Baker built models? Baker Built is now on the upper side of belt & Smooth Spyder is on the lower side of belt. I may be looking for a magic vibration solution caused by engine internal balance issue.- but I'm no quitter
Thanks for any conclusive help.
Darrell
Darrell
Haven't compared the two head to head but I do have the Baker tensioner and was suprised that it was on the top belt. I didn't expect much when I installed but was very pleasantly suprised at how well it worked.
Smoothspyder is on the top as well.
on the top of the bottom :-(
Say what??
http://www.smoothspyder.com/belt-tensioners/
My Smoothspyder...
Mine is on the bottom of the bottom, pushing up. On an RT Limited.
I have an RT and mine is also pushing up from the bottom, on my Smooth Spyder that is.
David
How old would you be if you didn't know how old you were?
Let's see..!!
smoothspyder on all models up to the F3 are on the bottom. The top is taught when on the throttle the bottom loose. However the F3 has a longer belt and I know baker added a top roller as well. Don't know that there are any upper lower for any of the 08 thru14's... don't know anyone offhand that has tried them both...
2012 RS sm5
Guys, this thread is in the F3 section. The SmoothSpyder tensioner for the F3 is on the top of the belt and like most of his products, very well designed and built.
The RT tensioners are on the bottom. Different belt lengths result in different vibration issues.
Different bikes; different needs... Thanks for reminding us!
SMOOTH SPYDER TENSIONER
The latest smooth spyder is on the top belt...works great!
Ron
WHICH IS EASIER TO INSTALL
Not being much of a mechanic, the Baker looks like it is easier to install and/or calibrate. Is that correct ? I worry about the bearings in them both, those things must be really hauling the mail ! Any insight would be appreciated !
" Fat people are harder to kidnap "
2015 RTS-SE6 Circuit Yellow
Akrapovic Exhaust - BajaRon Sway bar
Rivco rear Trunk Rack
Lamonster LED Head Lights - LED Fog Lights
Spyder Cuff - Hwy Pegs
Ultimate Midrider Seat w/ Yellow Trim - Rear Armrests
Spyderpops Bumpskid with LED - Full view Turn Signal
R/T Front grill Inserts
3rd Brake light - Saddle bad LED
Baker Built Air Wings
Doc's Spring Stiffeners - Vibration Dampener
TRICLED underground LED'S
Do we have any reports of how BRP's tensioner is working out?
I have about 1k on a BRP tensioner...works great! On top by the way.
2015 F3 SE6 Black and Chrome, Smoothspyder Backrest and more to come.
The BRP one is just for the F3 right ? I need one for the RT
Originally Posted by Bruce B
Doc Humphreys has an adapter for the use of the BRP tensioner on the RT. I believe they are for sale now, but there are 5 of them going to testers that will provide test data and opinions on them. Contact Doc Humphreys for more information, but it is said that they actually work better of the RT than they do the F3
David
Smooth syder
A plus on quality, easy to install but no long term results other than the bike hauls butt without any vibes up to 80
I know an F3 rider in Canada who did Beta Testing on the BRP tensioner, and reports that the difference is remarkable. Rode from Ontario to SpyderQuest & back and was very comfortable with the long ride.
Idler pulley
Just installed a BRP idler pulley $40.00 took 40mins have to remove 2 panels on f3t . Remove 2 bolts and install. Took for ride vibes all gone what a pleasure to not have to ride around the belt vibrations.
Idler pulley
Darrell
installed on my f3t a BRP pulley took 40 mins , works great no more vibes.
Made for us version
The Australian bikes have smaller rear sprocket with shorter belts hence the BRP roller sits about 1.5 inches lower = lower tension on belt.
It still improved 60 mph vibrations. I now notice vibrations on foot boards from engine vibrations and handle bar vibrations a little more.
My F3S is much smoother. What surprised me was how much less fatigue I experienced. I believe we all notice the heavy vibration at 55-65 mph, but there are low frequency vibrations that we are unaware of that will began to ware on the rider. I think it is a very important install.
I noticed the same vibrations. I am still very pleased with the tensioner...
2016 Can-Am Spyder F3 Limited
