2011 RT-S SM5 - Black
I'm too chicken to guess at anything...
Lamont posted pictures of a key taken apart, and it was pretty clear that you couldn't hit the chip with a hole up at the top of the key.
The hole is actually already there!
Take a pin, and push it in at that spot; it'll go right on through!
That metal, wont it scratch? I had the same issue with my yamaha key scratching so i wound up getting one of those key chains that come part, like an air compressor fitting and super gluing the female part onto the side of my yamaha key. Actually works out really well cause i can put the spyder key on the same ring.
Tony From Los Angeles
Current
2015 Spyder RT
2012 Yamaha FZ6R
Previous
2008 Premier GS #588
2005 Suzuki C50
2007 Susuki S40
Well rode to work and when I got home the holder was laying on carport in spot where I park. So much for being observant. Thanks for all the help. Found that part number but could not believe the price for a small piece of plastic. RWC
Your Warranty has been restored, with a caution.
here is my key holder, google BMW silicon cover for more info comes in multiple colors
Cruzr Joe
Responding to old message, but .......
I ordered a 710001102 to replace my lost scabbard/sheath (BRP call it a FOURREAU). Unfortunately, it does not fit the key to my 2008 RS SM5 Maybe earlier models had a fatter key?
John K
Odd.... I looked up the part number for that for the 2008. It lists the same part number!
Not sure what to tell you. Your key is a real can-am key correct?
Maybe there is some plastic flashing from the molding process that inside the holder keeping the key from going in?
Bob
