Rt rebuild
Have had my 2015 rtl on jack stands 27 inches off the cement for 4 days now installing farkles. Swaybar,smoothspyder, cat delete pipe, Trunk brake led light bar, 3rd and 4th led brake light, missing belt guard, brake return spring, led bump skid, day time running lights, mirror turn signals, 2 drink holders, large brake pedal, mud flap, Flag holders, Brake light strobe, Lidlox, Gel pad in the seat, 12 volt outlet on the dash. Led light strips for 622 trailer.
I think I have the belt tension set right at (180 pounds ?) and the smooth spyder at 12 pounds.
I hope it runs right after all of this because if it doesn't, I wont know which one the electrical farkles the problem is. I tested each one after install by just turning on the key but have not run the engine.
It might feel like a different bike. Hopefully I will get it all finished up today and test drive it this evening.
Tell me about this "Brake Return Spring", i assume its because of the heavier oversized brake pedal. What is it and where did you get it?
Thanks
Cruzr Joe
Video of your installation
For us none mechanics could you provide a video of your efforts-- Please.
Thanks,
Blade
I hope you have some money left over to buy gas!
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
Spring
I will try to make a little video tomorrow on the brake spring.
I didnt realize how much farkling cost, but man, you can spend 3 grand real quick.
But the good thing is I still have .47 cents for gas, soooo, lets ride,,
Neck of the woods
Thanks,
Blade
I used to live in your neck of the woods. I lived in Hampton.
Impressive FARKLING!!! Not only will it feel like a new bike, but it will look like a new bike with all of the additional brake lights, etc. You may want to take a picture of your license plate so you will have something to refer to in case you don't recognize it.
2014 Spyder RT Limited SE6
BRP Tri Axis Adjustable Handlebars
BRP Adjustable Wind Deflectors
BRP RT Passenger Armrest
BRP Driver's Backrest
BRP Travel Cover
Baja Ron Swaybar
SpyderPops KOTTS
SpyderPops Bump Skid
Lamonster NVB Highway Brackets w/ Gripper Pegs
Lamonster LED Headlights & Fog Lights
Custom Dynamics HMT Brake Light
Show Chrome 7.5 inch Spiral Antenna
SpyderFlap Mud Guard
Helmetlok w/ T-Bar Extension
Hopnel 5PC Luggage Set
Airhawk R Seat Cushion
Rivco Dual Flag Mount
UH OH
I woke up this morning with the anticipation of finishing the seat on my bike and the farkling will be finished, BUT, the .47 cents I had left over after farkling was for gas money,, well,, the wife took .25 cents of it for her lunch,,,sooooooooo, I might go somewhere on .27 cents worth of gas but I will never make it back.
Well, lets see if this works,,,
https://youtu.be/tMR5DzgB3wc
I just forgot to add in the video to make sure you put the cotter pin back in ,,lol
Be safe
Things forgotten
I forgot to mention putting the cotter pin back in the clevis pin when finished and also the washer needs to be on the side that I showed. If you put the washer on the side that has the cotter pin, the spring will rub the wires for the brake switch and who knows what kind of code you will get for that? ( passengers side window down?) I don't know.
Safe riding.
2015 RT "Re-Build"
Swaybar,
smoothspyder,
large brake pedal
Brake light strobe
I think I have the belt tension set right at (180 pounds ?) and the smooth spyder at 12 pounds. It might feel like a different bike. Hopefully I will get it all finished up today and test drive it this evening.
SpongeBob2015, I edited your post to identify the items I was interested in potentially buying for my machine. Can please supply specifics -- Part#, location you purchased it from, LINKS?
Thanx in advance,
- Jim
Thanx in advance,
- Jim
BajaRon makes the swaybar and Cpt-Jim makes the SmoothSpyder belt tensioner. Both are sponsors and you can find links to their info on the home page.
2010 RT- 622
Exactly
rt rebuild
The spring is a great idea ,nice video really helps thanks.
Be safe
Very nicely done, great ideal on the spring, and the rest of your mods are impressive. Looks like your Christmas came early, and now go take a good long ride.
David
How old would you be if you didn't know how old you were?
Well done , great idea on the spring and large washer configuration ----
That's a lot in 4 days. It would have taken me two weeks
2014 RTL Platinum
http://www.smoothspyder.com/
2014 RTL Platinum
