Results 1 to 10 of 10
    Active Member Pappy John's Avatar
    May 2012
    Susquehanna Valley
    Default Parking brake issue - 2012 RS
    When I de-actuate the parking brake pedal, the pedal comes up fast, but the brake pulley releases really slowly. This puts slack in the cable, allowing it to pop off the pulley.
    I removed the pulley and found that the caliper actuator (little stub shaft with the splines) that used to move fairly freely now has very sticky rotation. It's little rubber boot was half way off allowing dirt to get into the mechanism.
    I want to clean and lube it, but I don't know if there is more to removing it than just unscrewing it from the brake assembly. Will small parts with springs come floinging out of that hole if I remove it?
    Also, does something like that require some special exotic hi-temp grease to work in such close proximity to the brakes?
    Nothing about this part is covered in my copy of the service manual.
    Oct 2013
    rome new york
    The only way to find out is do it.
    Just be careful and go slowly
    May 2012
    Susquehanna Valley
    You're right, of course. Tomorrow first thing I'll do it.
    I'm probably over thinking it anyway. There's no reason for anything small to be in there if it works the way I think it does.
    Jun 2010
    Las Vegas
    Quote Originally Posted by Pappy John View Post
    Might be a good idea to invest in a service manual, you can buy an online version for around $20.00. Then there will be no limit to what you can do on your Spyder.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Default Try this..!!
    go to cheapcycleparts.com and check the parts blow up to see whats invoved.
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Bossier LoUiSiAna
    Ask a tech @ dealer, make friends & show you know enough , but your just curious
    May 2012
    Susquehanna Valley
    Yeah..... I've had one since day one..... and the parts diagram doesn't single this part out for some reason. Never shows it as being removed from the caliper assembly. Curious....
    Try this..!!
    Same picture.
    I'll get back to you after I've taken it apart and (knock, knock) re-assembled it.
    May 2012
    Susquehanna Valley
    Nope. That won't come out unless I remove the brake cylinder itself. Rotating CCW it comes out about a half inch then stops. Being retained by something outboard of the cylinder.
    Sounds expensive to me. Rear caliper : $506.99 ETA: found it for $380 elsewhere. Still......
    Jul 2011
    Mitchell, Ontario, Canada
    BRP considers the brake caliper assembly a non serviceable item. That's why no instructions in the service manual and no individual parts available in the parts catalog. I have not had one apart but I assume the other end of the spline shaft is in the brake fluid, behind the piston. So I would be careful that anything I used to lube it is compatible. Why not screw the shaft out as far as it will go. Clean it with brake clean. Let it dry. Then lube it with brake fluid.
    Good luck and let us know how it works out.
    May 2012
    Susquehanna Valley
    That is what I did. Seems to be working OK for now, but the rear of the pulley is rubbing on it's spring at the spring retainer point. Maybe that is why the pulley was returning so slowly.
    That can't be right.
    I'm suspecting that the spline shaft and pulley have traveled inboard that far because the pads are about shot, so I ordered a pad kit. I'll have it by this weekend.
    Thanks, Everyone.
