Originally Posted by cheska
Nice trailer
Plate blocked
Here in Ca you would have an issue with the hitch blocking the license plate. I have also heard, but never got a real answer about warranty issues on the F3 and a hitch.
Very nice..!!
nice setup. Looks like you have to remove the rear axle but is well made and should do the trick well. Cool trailer... can't beat the price either...
blocking plate
the hitch can be unbolted with 4 bolts the side plates stay attached to the frame that way you can remove the hitch when not in use . They can not see the plate when you are pulling a trailer so if you remove when not pulling trailer you should be alright
the guy that sells them was at spyderquest this year with the same f3 that's in his picture on ebay. looked like a nice set up!!
