Flashing led's spyderpops bumpskid
I want to add a switch and flasher to my spyderpops bump skid that came with leading edge led's
I lead funeral escorts for the local Patriot Guard missions and have always had white led's that blink or strobe. I think a flashing bump skid would add visibility during processions.
Anyone have any thoughts or comments about what I need to do. I have the flasher setup for my hyperwhites, but the (separate) flasher is only working two pods of 16 led's each. It's spec might be for up to 6 pods so 96 led's. I could try wiring that in the circuit, but it seems there's lots more led's on the bump skid.
Any specific component you can point me at would be appreciated. I'd wire in a 2 throw switch so it's either solid on for normal use, or flashing for processions.
thanx
we always run our emergency flashers for such events. good news is I have the fender tri-led kits to be wired into the turn signals.
I'll then be thinking of what I want to do with the rear. It would be some kind of white led's that flash.
let's ride safe & be careful out there,
Mike in Nawlins'
2014 Black SE6 Limited "Charlotte"
New Orleans Ride Captain
Patriot Guard Riders
2015 RT Limited Intense Red Pearl
Remote
I have the spyderpops remote, its awesome..........
I bought a same make/spec unit from amazon and tried it. The unit says it's 12amp, but the instructions spec shows 6amp. Regardless, the receiver got very hot and had very little effect on the led's. The remote was working (red light on when button pushed). Either it's defective, miss marked for 6amp, or isn't going to work because of too many led's and load.
Bought another and will see and report.
Mike in Nawlins'
duh...I had the polarity right but not the flow...as in the correct end connected to bike/battery side and the other connected to the led's
now that it's correct, works fine and is very cool.
Mike in Nawlins'
Besides turning the LED's on and off, strobe lights, dim lights…what else does the remote allow you to do?
I was hoping for "white".....
YOU WANT WHITE, YOU CAN'T HANDLE WHITE, wait a minute that was another argument, let me see if he has "White", yes he said that he has any color "White" that you want.
and next week he will be getting in some "White Ones"
Anonymous
