Results 1 to 6 of 6
Thread: Engine number
    Jul 2015
    Australia
    Default Engine number
    Can anyone tell
    Me engine
    Number Location? I found it in the book but not the bike.....And do you have to pull half the bike apart to find it?
    2009
    Jun 2010
    Las Vegas
    I'm going to guess that you'd need to take apart more than half of the Spyder to access the engine id
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Default Here you go..!!
    Inot easy this picture is with the engine out so you will have to take the left side panel maybe more.
    pulling the oil inspection cover you will see the engine sproket and belt so it will be right behind on the engine case below the rear engine mounting bolt...hope it helps...
    Jul 2015
    Australia
    Thanks for that, I had to get a new number plate
    , so had to find the engine number, what a mission, still didn't find it with the cover off, even seeing where it is located via the manual.
    Whoever decided to put it there needs a good flogging!
    Quote Originally Posted by 109spyder View Post
    It's probably the same guy who decided where to put that rear tire valve stem.
    (It must be some twisted Canadian version of "Where's Waldo?"...)
    The 1330 engine number isn't as hard to find but you might have the same luck as I did if you remove the Left middle side panel (#1 in the 2009 manual, pg 89) and use a swivel head mechanic's mirror to read your number. You might have to get a rag in there to clean dirt off the engine to read it.
