Results 1 to 10 of 10
    Active Member Olddood's Avatar
    Oct 2011
    Niagara Region Ontario Canada
    Default F3 Limited swing arm
    Does anyone know if the Swing-arm on the 2016 F3 Limited and the F3T are the same as base F3 models. They now have air shock for these and I was wondering. I can't find a photo of the rear wheel with swing arm anywhere that I looked. Thinking ahead for winter projects...
    Lamont posted that they were different on the F3-T and F3 Limited models...
    Oct 2011
    Thanks for the reply Bob.
    I must have missed that one. Probably not worth the expense for a swap.
    Default Just in case...
    cheapcycleparts.com has parts break down for all models. You can check part numbers to see, for this and other items . If they are different I would not believe the shock mount would change unless the shocks are different as well...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Very Active Member spydaman60's Avatar
    May 2012
    sussex, nj and tug hill, ny (west turin)
    gene, I don't see any specs for 2015 and the f3 on cheapcycleparts.com. is there a special site for this?
    Just looked and they are all there. You go to oem parts then can am then spyders. There you have the parts list swing arm runs 354.00
    ​2012 RS sm5
    May 2012
    thanks
    Very Active Member 900Dave's Avatar
    Jun 2013
    Fleetwood, PA
    Default NO
    Quote Originally Posted by Olddood View Post
    It is my understanding that the new F3T & F3 Limited have the same swing arm as the RT. This allows for the trailer hitch and the airbag.
    2016 Spyder F3 Limited Steel Black Metallic
    Lamonster approved LED Headlights
    Lamonsters LED Fog lights
    BRP Driver & Passenger backrest
    BRP Trailer Hitch
    Shamrock Black & Polished
    Signature light
    Elka front shock's
    Rolo Laser Alignment
    Dual Power outlets
    Garmin 590 GPS
    Mar 2013
    Quote Originally Posted by 900Dave View Post
    That is what I was also told.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Springfield, MO
    It's the same type but not the same swingarm as the RT. The hitch is a different part number too.
