Have heard that from 2013 forward ALL handle bars between models are interchangeable. (This does not apply to the new F-3's).
If this is infact true; are the handle bar ends interchangeable also from one model to the other??
The reason I ask is I would like to get a used RT handlebar to replace my stock bar on my RS. Need the extra back set towards the driver to allow my arms to be more flexed and relaxed. I would like to keep my OEM cruise control which I added to my RS.
Await replies from those with technical knowledge. Thanks in advance for your help and insight.
Al
2018 F3-T
The handlebar nomenclature is a bit confusing if you think handlebar as in F3 or regular motorcycle. If I understand you correctly you are going to replace the ST handlebar, part #709400985, with the RT handlebar, part #709401194. You will bolt to the new handlebar the current ends of your ST bars, i.e., twist grip, L & R switches and grips. In my mind what BRP calls handlebar in the parts diagrams I would more appropriately call handlebar frame. To make the swap out, if you have an SE you will also need part numbers 709400577, 709400578, (or if an SM 709400741), eight 205041094, 709400579 and four 210251680.
****************************** Cognac 2014 RT-S
From all the post I have read; yes they are all interchangeable
RT bars are easy to find used as many RT guys have switched to the axis adjustable bars.
I put ST bars on my RS. This is the greatest mod. They are a night and day difference.
Now I have no pressure on my wrist, arms, and back.
Riding no longer aggravates my carpel tunnel.
Now I understand you RT type cruiser guys; never wanted to go more than 50 miles before.
Now I'm ready for a real road trip. ST bars and ST seat on my 14RS is a great combo.
Next mod is to lower (2") and move my floorboards forward 2 inches.
Now I will keep this RS till it's out of warranty April 2018
Al
You may want to start with some ST bars? I think the "set back" of the RT bars might be a little more than you want IMO.
Congratulations! You now have an ST with RS headlights, mirrors and gauges. Enjoy the ride!
2016 Spyder F3 Limited Steel Black Metallic
Lamonster approved LED Headlights
Lamonsters LED Fog lights
BRP Driver & Passenger backrest
BRP Trailer Hitch
Shamrock Black & Polished
Signature light
Elka front shock's
Rolo Laser Alignment
Dual Power outlets
Garmin 590 GPS
You will have to cut some tie-wraps under the tupperware to get enough slack in the wires for the longer handlebars but the wires have plenty of length.
